Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Have you selected the transmission type and clicked OK?
Also under Partner/Group choose Ame
sergio
Year and Model: S60 2002
Post by sergio »
Yes I did that too. Which position is the key supposed to be II, III or engine running? I tried on I, II, and III.
S60 2002 180K miles looks and runs like new (except when sulking)
I get greyed out communication tab on my Vida install until transmission/engine is selected and I click OK.
Even with no Dice connected the above is true.
Pos II for ignition
sergio
Post by sergio »
I don't seem getting any answer to my prayers! 3 weeks without my S60!
What am I missing?
Sorry obvious question but are you clicking OK after selection?
Also choose Ame under Partner Group as stated in previous post?
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
click the software tab first, then the diagnostics tab becomes available.
jda2000 wrote:click the software tab first, then the diagnostics tab becomes available.
Never had to do that with either of my Vida installations, but what the heck you've tried everything else!!
sergio
Post by sergio »
precopster, you were right again. I forgot totally the most obvious, to click OK !!
I am going to install adobe acrobat printer so I can get a copy of the results.
So far I see the same OBD II codes but in Volvo language; 9150 9150 9170.
I need more and detailed info from it.
sergio
Post by sergio »
It seems that it is working only, I have difficulties understanding the Swedish accent :lol:
ECM-913C Throttle valve Faulty signal
ECM-9150 Throttle unit, potentiometer 1 signal too high
ECM-9160 Throttle unit, potentiometer 2 signal too low
ECM-9170 Throttle valve Faulty signal
then a lot of
Checking for knocking and rasping
Checking injectors etc etc
explanation for ECM-9150
-Contact resistance or oxidation in the terminal between the engine control module and the throttle unit
-Open circuit or short circuit to supply voltage in the signal cable
-Open circuit in the signal ground cable for potentiometer 1 and 2
-Defective throttle unit
I had these possibilities in mind 3 weeks ago. But I expected to get a better answer with Dice Vida.
So how do I narrow it down before buying a Throttle box then realizing I only needed to change the cables or vice-versa?
Remember
I cleaned the throttle box mainly because I was cleaning the PCV. Although I had rarely but still sometimes this oscillating idle that would come on as I started the (cold) engine. I would stop the engine after a minute or so and restart, the engine would fire with a normal (constant) idle. I would be to take over other cars like a F15. :lol:
Looks like you'll be visiting a sponsor's site to buy a new throttle unit. Choose a Bosch unit as this is as good as what the factory provided.
I'm assuming you've checked the throttle unit connector and terminals for corrosion?
