Have you selected the transmission type and clicked OK?
Also under Partner/Group choose Ame
Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
- Year and Model: Lots
- Been thanked: 128 times
I get greyed out communication tab on my Vida install until transmission/engine is selected and I click OK.
Even with no Dice connected the above is true.
Pos II for ignition
Pos II for ignition
I don't seem getting any answer to my prayers! 3 weeks without my S60!
What am I missing?
What am I missing?
- Clipboard01.JPG (117.31 KiB) Viewed 4532 times
S60 2002 180K miles looks and runs like new (except when sulking)
Sorry obvious question but are you clicking OK after selection?
Also choose Ame under Partner Group as stated in previous post?
Never had to do that with either of my Vida installations, but what the heck you've tried everything else!!jda2000 wrote:click the software tab first, then the diagnostics tab becomes available.
precopster, you were right again. I forgot totally the most obvious, to click OK !!
I am going to install adobe acrobat printer so I can get a copy of the results.
So far I see the same OBD II codes but in Volvo language; 9150 9150 9170.
I need more and detailed info from it.
It seems that it is working only, I have difficulties understanding the Swedish accent
ECM-913C Throttle valve Faulty signal
ECM-9150 Throttle unit, potentiometer 1 signal too high
ECM-9160 Throttle unit, potentiometer 2 signal too low
ECM-9170 Throttle valve Faulty signal
then a lot of
Checking for knocking and rasping
Checking injectors etc etc
explanation for ECM-9150
-Contact resistance or oxidation in the terminal between the engine control module and the throttle unit
-Open circuit or short circuit to supply voltage in the signal cable
-Open circuit in the signal ground cable for potentiometer 1 and 2
-Defective throttle unit
I had these possibilities in mind 3 weeks ago. But I expected to get a better answer with Dice Vida.
So how do I narrow it down before buying a Throttle box then realizing I only needed to change the cables or vice-versa?
Remember
I cleaned the throttle box mainly because I was cleaning the PCV. Although I had rarely but still sometimes this oscillating idle that would come on as I started the (cold) engine. I would stop the engine after a minute or so and restart, the engine would fire with a normal (constant) idle. I would be to take over other cars like a F15.
then a lot of
Remember
Looks like you'll be visiting a sponsor's site to buy a new throttle unit. Choose a Bosch unit as this is as good as what the factory provided.
I'm assuming you've checked the throttle unit connector and terminals for corrosion?
- 97 Replies
- 15638 Views
Last post by bmdubya1198
- 16 Replies
- 4250 Views
Last post by daninater
- 8828 Views
Last post by MadeInJapan
- 1436 Views
Last post by 800artfreed
- 37 Replies
- 37797 Views
Last post by chitownV
