Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
- Year and Model: Lots
- Been thanked: 128 times
A cheapy throttle body sold in the USA: http://www.ebay.com.au/itm/230932295891 ... 1423.l2649
Love the way they say it fits but may require dealer programming.precopster wrote:A cheapy throttle body sold in the USA: http://www.ebay.com.au/itm/230932295891 ... 1423.l2649
True though FCP say that about their OEM Bosch ones as well and they should know betterRocky wrote:Love the way they say it fits but may require dealer programming.precopster wrote:A cheapy throttle body sold in the USA: http://www.ebay.com.au/itm/230932295891 ... 1423.l2649
Very interesting, they all say "may require dealer programming"precopster wrote:True though FCP say that about their OEM Bosch ones as well and they should know betterRocky wrote: Love the way they say it fits but may require dealer programming.
Wonder if they know what they are selling
S60 2002 180K miles looks and runs like new (except when sulking)
Had replaced MAF now replaced Throttle Body. The result is; there is no change
The engine started with several big bangs (backfire etc) then went rumbling (oscillating RPM) again.
I let it run for few minutes then it stopped.
I'm attaching 2 printouts.
What am I doing wrong?
1.pdf- printout of Dice Vida
- (17.2 KiB) Downloaded 450 times
2.pdf- printout of Dice Vida
- (17.02 KiB) Downloaded 242 times
Adapatation process. Was it done according to the PDF I attached?
One of the attachments has me confused. It says 99% turbo pressure and 2.7% desired throttle angle. Is the car at idle during this table?
jimmy57 where are you?
When you look at the throttle adapatation in ECM module does it still say that throttle is not adapted?
These are the printout of the reading I get.
You told me that to activate a Bosch (non Magnetti) unit all I had to dowas to clear the code, start the engine, let run for a few minutes then it will set itself.
The codes don't clear. I mean they come back right after they are cleared!
xmlDocPrintPreview.pdf- adaptation
- (33.91 KiB) Downloaded 176 times
activation.pdf- activation
- (19.81 KiB) Downloaded 201 times
5.pdf- after I press next /ok
- (9.04 KiB) Downloaded 201 times
Hi Sergio. You really are having a rough time with this aren't you?
These docs don't show the state of throttle adaptation. The area is in Vehicle Communication and then click Parameters Tab then then the ECM module icon then plus sign to find Adaption Throttle Unit. Double click it. It will then show you the state of the adaptation.
What does yours say Sergio?
- 97 Replies
- 15638 Views
Last post by bmdubya1198
- 16 Replies
- 4250 Views
Last post by daninater
- 8828 Views
Last post by MadeInJapan
- 1436 Views
Last post by 800artfreed
- 37 Replies
- 37797 Views
Last post by chitownV
