I have a 1998 v70 that keeps stalling after about running for about 10 min. the car wont start back up for another 15 min, then starts and runs fine until it gets cold again. I was having the problem with no codes before but the cel just came on with this
p0340 cam sensor
p0103 Maf
p0455
p0442
Now I can easily install a maf and cam sensor but would it be necessary to change both? or just one? are they related? any info on the other codes too? any help will be appreciated, Im thinking about selling the car for cheap.....Thanks
1998 volvo v70 stalling, 5 codes
try cleaning your maf sensor then unplug both cables that run to the battery. touch the pos and neg cables together (OFF THE BATTERY) todo a hard reset. then leave them off for about 30 min to be sure codes are gone. if it keeps stalling go ahead and replace the cam sensor, clear codes and see what happens. you can also just try disconnecting the maf sensor and see if theres a change.
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
- Has thanked: 1611 times
- Been thanked: 4075 times
Jon - dont dismiss the possibility that you have one major thing wrong with your car, and the poor running is throwing a bunch of codes out that dont necessarily point to bad parts.
The P0455 and P0442 codes are EVAP system faults - the poor running might have blown off a vacuum line in the evap system for example.
The codes guide you, but you still have to diagnosis spark, fuel, compression ...in that order, to do this efficiently.
I would suspect a fuel pump relay if it is a sudden quitting of the engine, for example.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If it won't run again with the MAF unplugged, it's not the MAF. Doubt the EVAP codes have anything to do with it whatsoever.
Id actually be inclined to pin this one on:
1) an overheating positive battery cable (feel the one heading to the fuse box when the car dies - is it extremely hot???)
2) An overheating/failing cam position sensor as indicated by the code. They get flaky with age and high heat.
'98 S70 T5
2016 Chevy Cruze Premier
ok did some more research, Im going to go ahead and replace the cam sensor first. Now my question about the MAF....I had the car running at idle and unplugged the MAF, the car ran ok with it disconnected but when i plug it back in it stalls....is it bad?
Thanks for the help....
abscate wrote:Jon - dont dismiss the possibility that you have one major thing wrong with your car, and the poor running is throwing a bunch of codes out that dont necessarily point to bad parts.
Is there a way to test the relay? with an ohm meter or something?
There are numerous posts here about bypassing it and seeing if that QUITS your quitting problem...I think that is the best approach.
jblackburn
Depends how it failed. It may fail only when hot...in which case, the car would start and then die out when it loses a reading from the sensor.Jonc123 wrote:another question....If the cam sensor is bad then the car wont start at all right?
'98 S70 T5
jblackburn wrote:Depends how it failed. It may fail only when hot...in which case, the car would start and then die out when it loses a reading from the sensor.Jonc123 wrote:another question....If the cam sensor is bad then the car wont start at all right?
It doesn't stall out when hot, Just when i drive down the road and come to my first stop. However I just disconnected the mass airflow sensor and the car did not stall out. It ran a little rough but didn't stall. So im going to go ahead and replace the MAF sensor. Im just not sure where im getting the cam code from so I inspected the connection and cleaned it out....
- 9 Replies
- 7758 Views
Last post by enriquepr21
- 9 Replies
- 4258 Views
Last post by eric v70
- 1838 Views
Last post by Samtara1
- 19 Replies
- 2701 Views
Last post by bmdubya1198
- 12 Replies
- 2576 Views
Last post by gvsu4msu
