1999 v70 cam seal
anniqu
Year and Model:
Post by anniqu »
I recently changed the cam seal on my 1999 v70. It appears that there is still oil leaking from the cap. What did I do wrong ??
Michael Paris
Has thanked: 311 times
Been thanked: 817 times
Leaking from the cap, which cap? Oil cap? If you mean distributor cap, than I would guess the seal is not seated properly or is nicked.
Changing the cam seal won't help with leaking from the oil cap. You'll need to change the gasket on the cap, and maybe service the PCV.
Been thanked: 4068 times
No distributor on a 1999...ETB and coils on plugs
DoH!
anniqu
Year and Model:
Post by anniqu »
I misspoke when I used the word cap. I was referring to the cover for the cam seal. There still seems to be oil running down from that cover.
Michael Paris
Been thanked: 504 times
Post by cn90 »
Either:
1. Old oil that you did not clean up after repair.
2. Bad seal, use only Volvo or SKF seals only.
Aha, then do see my striked out text above, i.e. could also be
3. not installed properly (is it straight/flat? flush with the outer surface?)
4. the seal was nicked or bent before installation
or even
5. some people find that surrounding the seal with a thin layer of silicone is necessary to get a good seal.
You're going to want to pull that cover and look at the seal; can you tell where the leak is coming from (or, as cn90 suggested in #1, is it really leaking at all?)?
anniqu
Year and Model:
Post by anniqu »
I am going to get the SKF seal . Is there supposed to one seal or two inserted ?? . I have cleaned the area after installing the new seal and the oil shown is after a couple of weeks of installing the new seal. Also I think I may have pushed the new seal too far in.
Michael Paris
Each cam has a rear seal and a front seal. They are different sizes. And there are two cams right, so altogether four seals. But if only one is leaking (the rear on the intake cam in your pics), then I would probably only replace that one. Your call, the rears don't take a lot of effort but I don't like to replace a part that isn't bad. Can become an expensive habit.
FWIW some people will swear that it is fine to push those seals all the way in so it may be, but I am certain they come from the factory flush.
Be sure to gently clean the bare surface of the cam from any buildup, that can also cause the seal to not work properly.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
On my '99 there wasn't even a seal there behind the cap on the intake cam and I tore the cap up pretty good getting it off. It appeared that there never was a seal installed. I don't know how they think you can get the old cap off without killing it.
I installed a seal and bought a new cover cap and no leaks.
