ETM repair for Australian/New Zealand customers
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
For those of you in Australia or New Zealand and looking for Magnetti Marelli ETM repair I've finally launched a website you can visit in addition to my eBay ad for ETM repairs.
It's a starting point but one I hope will expand with more services and products as the needs of local customers grow.
Here's the link: http://precisioncarmodules.com/home
shanegtr
Year and Model: 1999 V40 2.0T
Post by shanegtr »
Hey Mike, just had a look at your site. I've got an issue (not related to ETM's) with my CEM on my V40. Intermittant wipers and rear window wiper not working. Traced the issue down to the relays so will need to be desoldered from the board and resoldered on, however I havent had much luck finding the required relays locally to suit a direct replacement. I was thinking along the lines of moding it to use a couple of readily available relays that are available at any autostore. Most likely outcome of this however will be the relays will have to be external to the CEM, so may require some creative wiring to do it. Have you ever had to do something like this or would you recommend spending the time to replace the relays with like for like? Just thinking long term it would be far easier for replacement if the relays are prone to failure.
Give it some Jandal!
Is there a photo of said relays with a clear focus on their part numbers you can post up on the board?
I may be able to source them with the aid of a visual.
shanegtr
Post by shanegtr »
Heres a link to another forum with some photos of the relays:
http://www.volvoforums.org.uk/showthread.php?t=67584
My numbers are slightly different to whats in those photos. I'll post up a pic of mine in the next couple of days (working N/S at the moment)
It may be a good idea to post up your photos as I haven't had any luck with the larger main beam relay. It looks like a National Semiconductor part. Let's see if yours is the same
shanegtr
Post by shanegtr »
Ok, I'll rip it apart tommorow night ( too buggered to do it tonight)
shanegtr
Post by shanegtr »
I found the bit of paper I wrote the numbers down on.
P1CN01ZW1
9915A
