I have to get new sway bars? Really?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
My front sway bar's bushings are toast, and squeak when I'm doing parking lot manuouvers. On early 850s the bushings are replacable, but not 1994+, from what I've read.
I've also read some owners have replaced them anyway, and some for some of them it turned into a fiasco and they threw in the towel and bought new sways.
Any thoughts? Anyone tried the replacement?
Sway bars I'd get iPD On sale for $348.50 until next Sunday.
Bushings at eEuroparts Just $11 for two.
Also -> Amazon link
DragosGD
Year and Model: S70 T5 - 1998
Has thanked: 9 times
Been thanked: 6 times
Post by DragosGD »
I just ordered mine (front) thru Matt from TASCA. Sway bar part# 9173982 (Marked code 1) $103.00
matthew1
Site Admin
Post by matthew1 »
Dragos, do you have a URL for that? The TASCA eBay store has no results for that part#.
Also -> Amazon link
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
From Vida
Stabilizer bar 1.00 9173982 -1997 MARKED 1, O.DIA 20 mm or (3546860)
Stabilizer bar 1.00 9173983 -1996 MARKED Y, O.DIA 21 mm, (3546861)
Stabilizer bar 1.00 9173983 -1997 MARKED 2, O.DIA 21 mm
Stabilizer bar 1.00 9173471 -MARKED A O.DIA 21.5 mm
Hope this helps. You may want to upgrade the diameter while you're there, Matthew
Been thanked: 4068 times
Nasty looking job on my 1999. Jack motor up a few inches, lowering sub frame, disconnecting steering gear. I wonder why the bushings were vulcanized to to bar on later models.
DragosGD
Post by DragosGD »
matthew1 wrote:Dragos, do you have a URL for that? The TASCA eBay store has no results for that part#.
This is a direct link to their store: http://www.tascaparts.com/partlocator/i ... eid=213668
Marked 1,2 & A are interchangeable parts?
Has thanked: 311 times
Been thanked: 817 times
All those fronts are interchangeable. If you buy an OEM bar, I'd get the thickest one (21.5 mm).
As for what cam on the car, you can tell by looking at the bars. Volvo mixed and matched the bars a lot. The best way to tell what a bar is, is by the paint splotches on it:
front sway bar part #s:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
rear sway bar part #s, probable O.Diameter:
9191459 (marked green) 19.5 mm
9191461 (marked yellow) 20 mm
9191462 (marked blue) 20.8 mm
9191494 (marked black) 21 mm
DragosGD
Post by DragosGD »
Thank you, I called TASCA and changed my order.
matthew1
Site Admin
Post by matthew1 »
Ok, thanks everyone. I'll check the current bar's diameter.
Also -> Amazon link
demian5
Year and Model: 1998 S70 GLT
Post by demian5 »
If I was going to have to pull the sway bar to change the bushings, I'd go IPD.
