Hi eveyone! I know there's a couple of dealers on here so hopefully someone can help me out. I recently replaced the PNP switch in my 1998 V70 XC and naturally the radio no longer works. I believe it to be the original radio for the car.
Information you'll need:
VIN# YV1LZ5649W2442129
Serial# VO8170 V9279116B
I'm not incredibly worried about anyone reading this and stealing my radio so responses in the forum are fine.
I did also play with radio a bit, so now it doesn't say "CODE" anymore, it just says "OFF"". Is this a major issue and how do I get back to enter my code once I get it?
Thanks for the help!
-Scott
Need radio code for SC-816
whitemountainnut
- Year and Model: V70 XC - 1998
1998 V70 XC - 159k - Sandstone Metallic
1998 V70 XC - 220k - Dark Olive Pearl (parting out)
- Has thanked: 1613 times
- Been thanked: 4078 times
You will need to turn the ignition on and let it sit for 3-4 hours before you can try the correct code again, if its like my 99
whitemountainnut
I hope that isn't the case
But if yours is the same model radio then I will assume it probably is the case. Bummer dude. I do have a working radio that I pulled from my other car so it's not like I'm driving in silence, but it's not the radio that came in the car and it's a bit worn.
Thanks for the response! One item down, now I just need to get the code
-Scott
-Scott
JRL
- Year and Model: Several
- Been thanked: 16 times
It's 2 hours, not 3-4, or just drive for 2 hours and don't turn the key off
If it is an original radio, I should have your code in a few minutes for you
whitemountainnut
Thank you JRL! I appreciate the help! I suppose it would be groovy to know if that happens to not be the original radio. It's supposed to be.
-Scott
-Scott
JRL
I'll need the rest of the numbers on the radio
whitemountainnut
JRL
Will be tomorrow
whitemountainnut
Thanks JRL! VERY much appreciated
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
How to find the code in case it's around your car somewhere:
How to enter the correct code:
- 1521 Views
Last post by E Showell
- 1485 Views
Last post by Pojo-
- 828 Views
Last post by cn90
- 5352 Views
Last post by andregtable
- 12 Replies
- 2324 Views
