Did you know? 🤔
1996 850R Rear ABS speed sensor 9162612 Removal Volvo 850R - Sensor seized
appropriatenoises
Year and Model: 1996 855R
Has thanked: 0
Been thanked: 0
appropriatenoises
Post by appropriatenoises » Wed Jun 12, 2013 7:48 pm
I'm in the middle of (1st) cleaning, then probably replacing the rear ABS sensors on my 850R. I've searched and searched, and can't find the info I need.
I have spent the last hour trying to pull the rear ABS sensors out of the "hub" (for lack of a better name), and I can't get either of them to budge. I've (of course) removed the 10mm bolt. Anyone else have this problem? Am I missing something? Should they be sliding right out?
9162612 for 1994-1998
9472171 for 1999-2000 bastards
-Steve
Past:
1977 240-crushed
1981 245-on a fenceline
1987 740-on a fenceline
1998 S70 T5M- sold.
1967 P220 (Amazon) - lofty ideal, not good for a pragmatist.
Currently:
1996 855R- paid more than I wanted, sunk in more than I should! But it's worth it.
Matty Moo
Year and Model: 850, 1996
Has thanked: 0
Been thanked: 14 times
United States of America
Matty Moo
Re: Rear ABS speed sensor Removal Volvo 850R - Sensor seized
Post by Matty Moo » Wed Jun 12, 2013 8:38 pm
They're a pain in the *ss. I wouldn't touch them unless I absolutely had to. Fronts almost always pop right out, even if they've been bathed in salt.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
nedro018
Year and Model: 1995 850 GLT NA 150K
Has thanked: 0
Been thanked: 0
nedro018
Post by nedro018 » Wed Jun 12, 2013 9:58 pm
use good quality "liquid wrench" product. let it sit for a day. drive the car to warm it up. apply again. let it sit for a day. then, when engine is cold, remove 10mm bolt, get a large screwdriver and start hammering lightly near the bolt pattern...try to break it free. the sensor -does- pull straight up. so, after you may have broken it free, use vice grips to toggle it straight up. use a little antiseize next time.
appropriatenoises
Has thanked: 0
Been thanked: 0
appropriatenoises
Post by appropriatenoises » Thu Jun 13, 2013 11:34 am
Giving liquid wrench a go as we speak. I know I can check resistance at the large connector to the ABS module for proper operation of the rears (which is why I'm troubleshooting/cleaning/possible replacing) My Resistance readings on the rear were:
Lrear: In the Mega Ohms
RRear: Open (no reading)
But can I check it right at the yellow connector in the trunk to rule out wiring problems elsewhere? Anybody know the pinout on the yellow connector?
Thanks!
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Has thanked: 0
Been thanked: 0
appropriatenoises
Post by appropriatenoises » Sun Jun 16, 2013 10:17 pm
Mark this one as resolved for any future unfortunate soul trying to sort out their ABS woes who have tried the ABS module re-solder to no avail.
1) I must be one of the 1% (those who's ABS problems are not due to the ABS module solder problem), because my ABS/tracs light was due to both of my rear ABS sensors being "dead" or open circuits. Confirmed by testing the yellow connector behind the back seat (pin 1 and 3 are one side and 2 and 4 are the other) New sensors installed and the ABS/Tracs lights are finally gone!
2) Removal of the rears: Matty Moo is right - a total PITA. And nedro018's suggestion is bang on. Lots of liquid wrench over a couple days and some heat with a heat gun and hammering as evenly as possibly maintaining the shape of the aluminum sheath. I ended up banging out the plastic (interior) of the old sensor, leaving only the sheath, which allowed me to get a large screwdriver inside the body of where the sensor was and bang it back. I also removed the E-brake adjuster and spring to give myself more room to work.
On to our next adventure!
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Has thanked: 0
Been thanked: 0
appropriatenoises
Post by appropriatenoises » Wed Jun 19, 2013 2:59 pm
Another Note: The Yellow Connector on the new sensor is a PITA to pull through behind the fuel tank and up to the hole where the fuel lines go. Here's how I dealt with it: I removed it and taped the bare spade connectors to the old sensor wires to snake it through.
- Cut the old sensors off their wires (helps with removal from the hubs anyhow)
- Remove the new yellow connector end:
1) Mark each wire as it corresponds to the number on the back of the connector using tape. I did this about 8 inches back from the connector, but you'll figure out a way to put them back in the right placement as you see fit.
2) Flip up the tab on the back of the connector (where the numbers are)
3) Use the end of a paper clip or a sewing needle to push the little tiny tab on the "top" of each "spade" connector (from the front) while wiggling the wire from the back, push slightly forward then pull the spade out.
4) Tape the new wires to one of the old ones and pull it through. You may have to break the clamp right behind the entrance to the fuel tank opening that holds the two fuel lines in order to free both old wires... don't bother trying to fit the new ones through there, just run them beside the clamp.
5) Re-assemble the new connector.
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Post by abscate » Fri Mar 16, 2018 4:36 am
You can bang out the ABS sensors in the back by pulling the wheel and hitting the outboard face with a blunt screwdriver or dowel through the brake adjustment hole in the rotor/ drum combination. Ezpz
There is a nice picture in this thread - look with a flashlight to get the end of the black plastic ABS sensor in your sights
viewtopic.php?f=1&t=84246
Link To Volvo Glossary
ZionXIX
Has thanked: 9 times
Been thanked: 42 times
ZionXIX
Post by ZionXIX » Fri Mar 16, 2018 5:52 am
I sure hope they got it figured out within the last 5 years.
RickHaleParker
Has thanked: 3 times
Been thanked: 560 times
RickHaleParker
Post by RickHaleParker » Fri Mar 16, 2018 7:50 am
That's a job for DIY Penetrating fluid.
A 50/50 mixture of 100% acetone and dextron/mercron ATF.
Mix only what you need today in a spray bottle. This mixture has a short shelf life.
The two fluids repell each other like oil and vinegar so you have to shake the bottle well before spraying.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
Trinidad & Tobago
Post by abscate » Fri Mar 16, 2018 7:50 am
Patience is a virtue.
Ive been doing a lot of editing of threads, putting part numbers into title for easy searching, so when I find a good discussion of a topic, I just tack it on.
