Transmission problems....what have I done now?
pikngrn
Year and Model: 855GLT, 1997,
Post by pikngrn »
I just bragged on how great my 850glt runs after the PCV replacement and the turbo oil return line/gasket replacement. No leaks no smoke! Then my daughter drove it for several days with no problems and then tonight it "lost acceleration" and she parked it. I came a few hours later & checked it out...no leaks or suspicious activity, it started right up, it drove and then I parked it and would not go into gear after that, forward or reverse. I shut it off & checked tranny fluid and it was runny light brown and overfilled . What did I do? Coolant is clean as is oil.
Gonna tow it to my generic shop & would love to tell them what to check. Any ideas?
Thanks!
pikngrn
Post by pikngrn »
Oh and FYI
*no codes at all.
*Fresh oil change after PCV job
*I have no idea what I'm doing
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Sounds like the transmission cooler is leaking. Have the shop dump the transmission sump and thoroughly run new Dex III through it to flush out the TC as well. Then pressure test the radiator cooler.
Hopefully the transmission can be salvaged...but usually antifreeze is the end of em.
'98 S70 T5
2016 Chevy Cruze Premier
wheelsup
Year and Model:
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
Yeah, the way coolant mixes with transmissions I would have expected a separate cooler mounted completely away from the radiator. Unfortunate many manufacturers still do this.
1995 850 GLT Wagon w/ 200,000 miles
Been thanked: 468 times
Post by cn90 »
Do a simple drain + refill (about 3.3 qts of Dexron-III), and see what happens.
All you need is a 24-mm wrench (search forum).
However, I am afraid your transmission is going south.
pikngrn
Post by pikngrn »
How much should I expect to pay for a transmission rebuild?
I haven't had tranny trouble in 30 years.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
If you have the money for a rebuild it might be nice to have all the internals replaced but a tranny swap might be the cheaper option. I would call around and see what shops are charging for a rebuild and compare that to the cost of a transmission.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
pikngrn wrote:How much should I expect to pay for a transmission rebuild?
You could find another 855 for the cost of transmission rebuild.
pikngrn
Post by pikngrn »
I just remembered that it is mostly water in the radiator because I was afraid to put antifreeze until I knew I had no leaks. I had a hard time getting a heater hose to stay in before I started the PCV job. Would water mixed in hurt just as bad?
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Probably not, I would still flush it out right away though.
2000 V70XC 160,000mi.
