I have a 2001 C70 with 125000 miles. Just the other day the check engine light came on while on the highway. For some time after that I noticed occasional surges at speed (eg 2000 rpm). I checked the fuel cap (a bad cap led to the check engine light 5 years ago) and it was fine. Now the engine runs fine (NO idling issues, NO starting issues) but the CEL is persistent.
I finally got the OBD2 checked this morning (unfortunately, no, I do not own a reader) and it returned codes 236 and 237. So far from my research this combination seems to most indicate a bad boost pressure sensor (photo attached).
First, am I right? Are there other likely culprits? Is there any simple way to test the sensor?
Second, are there any risks to my replacing this myself? The location on this engine is very accessible, and only two torque screws stand in my way. After recently investing a lot of money in new brakes and new tires, I really want to avoid a $200+ mechanic bill if I can.
Third, if replaced, will the codes and engine light clear themselves after enough driving, or am I forced to use a code reader to clear it?
Thanks for any insight and advice.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
A bad MAP sensor is possible...but I'd start at the turbo control valve vacuum lines first. The valve is attached to the back/left side of the air filter box. Follow each of the 3 vacuum lines to the turbo, inspecting them for splits or cracks at both ends.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 312 times
- Been thanked: 818 times
Not sure about your 2001, but for the cars in this forum you can always reset the engine codes and the light (CEL) by just unhooking the battery.
- Has thanked: 1611 times
- Been thanked: 4075 times
The MAP sensor on the Electronic Throttle Body (ETB) cars lives down on the ETB horn in front of the engine. Its the one nearest the passenger side. It is a delicate little beast of a sensor on a long thin wire - be careful removing it and inspecting it. Sometimes the damage is obvious, which confirms the diagnosis. Before removing it though, try removing the cleaning the electrical connector - which will give the same codes if they get dirty.
- 8087 Views
Last post by adrian22
- 1302 Views
Last post by biohazrd76
- 4236 Views
Last post by precopster
- 41 Replies
- 10958 Views
Last post by EngineeringBloke
- 1513 Views
Last post by jimmy57
