weird behaviour of signal lights
mickeyk
Year and Model: s80 2003
Post by mickeyk »
Hello,
I would appreciate advice.
Exterior signal lights right/left/front/rear are functioning correctly in each situation, signaling left/right/all 4 together .. but -
the dashboard [green] indicators' arrows and the audible-sound [the tic-tac sound when one is turning right/left..], sometimes works and sometimes not.
Sometimes the arrows works without the tic-tac sound, and vice-versa [sound is on, arrorws does-not blink..]
I had checked fuses, looks to me ok.
I disembled the panel, and checked the small indicators bulbs that in the rear, both are ok.
Any suggestions?
Thanks in advance.
Mickey-K.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Sounds like an ignition switch issue. Jiggle the key when they're not working and see if they start working again.
If that doesn't do it, the turn signal relay is contained in the hazard switch.
'98 S70 T5
2016 Chevy Cruze Premier
liljohnny1999
Year and Model: s80 2000
Post by liljohnny1999 »
My stirring console goes dead after a while, no turn signals, no radio or cruise control. To fix I go to the fuse box on the drivers side and pull out the 5amp in location 21, put it back in and I am good to go for another 2 months. Another electrical quick from Volvo.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
There is a software upgrade that addressed steering wheel module issues that lead to SWM shut down. Volvo dealers can install the software. If your dealer is good then they may install that free with some other paid work.
The flashing of turn signals on network cars is done differently. The flashing is resident in the CEM and REM with the DIM (inst cluster) having a noise maker for the clicking that clicks in concert with the green indicators blinking. DIM issues internally or with power supply, ground, or the harness connector can cause your troubles. When the clicking and flashing is not occurring does the tachometer, speedometer, etc still work in cluster?
