New member here. I assume this applies to the S60 AWD as well. I'd be much better off with a 2003 compared to 2002? I'm currently looking to buy (U.S. model in California). Thanks.JRL wrote:I hate to be the bearer of this news but this one sounds as if it's not going to be worth fixing and why did she buy an AWD living in Fl, it's really not necessary and up THRU the 02 model year, the AWD system can be complex nand are VERY expensive to maintain
After 2003 the AWD system is very different and much more forgiving
What do I fix first?
Re: What do I fix first?
Nevermind. Found my answer. Seems all S60 AWDs utilized the newer system.gugle wrote:New member here. I assume this applies to the S60 AWD as well. I'd be much better off with a 2003 compared to 2002? I'm currently looking to buy (U.S. model in California). Thanks.JRL wrote:I hate to be the bearer of this news but this one sounds as if it's not going to be worth fixing and why did she buy an AWD living in Fl, it's really not necessary and up THRU the 02 model year, the AWD system can be complex nand are VERY expensive to maintain
https://www.matthewsvolvosite.com/forums ... =1&t=48417
BTW, best of luck to the OP with your XC.
JRL
- Year and Model: Several
- Been thanked: 16 times
Correct
AWD with Haldex started in 02 on the S60s then in 03 on the V70s.
