I checked the relay old fashion way; gave 12 volts to the magnet poles and a: heard the click b: measured a continuity on the other two poles. It is working I am sure.precopster wrote:What circuit did you transfer the problem to or did you use a new relay? So you have 12V at MAF? Do you have 12V at throttle connector?
Remember the throttle needs adaptation as it never had voltage.
Did you clear codes?
MAF has 12V
TB does not
According what I have read here, Bosch ETAs auto set after 20 seconds of key on position 2.
I clear the codes and click read vehicle I do >update data.
