Another issue seal leaking :/
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There is no seal there. if fluid level is high enough, like when engine has been off for a while and torque converter drains back into sump, then fluid is high enough to come out there.
The cup you put back in place may stop fluid from the bore inside splines but the axle gear the axle inserts into inside diff unit but the axle gear is not sealed to the diff case inside diff.
number 46 goes there...There is a seal there.jimmy57 wrote:There is no seal there. if fluid level is high enough, like when engine has been off for a while and torque converter drains back into sump, then fluid is high enough to come out there.
