Getting ready for the head tear down. Any tips?
Has thanked: 1611 times
Been thanked: 4075 times
it will be my catering/ hauling food mobile.
Mkaing those repairs fully tax deductible of course...see your CPA to confirm, Shirley.
bags519
Year and Model: 2000 V70 XC
Post by bags519 »
Yep done and done....:grin:
But I want to write it off running , without leaks. At least of the spraying variety.. drops I can can deal with.
Current Vehicles
2000 V70 XC (New Project)
2000 S70 SE 2.4 Manual (Daughter)
2004 VW Jetta GLS (Daughter #2)
1997 Chevy K1500 (Work)
2002 Chevy Silverado (Son)
2006 Audi A8
1985 Yamaha Venture Royale
bags519
Post by bags519 »
Well, I keep thinking about this leak and searching, I did not think that the oil supply line would be under pressure, I swear I read something to that effect somewhere. But I found a video that makes me feel like I may have a cracked line.. Whether it is the supply or return, I'll find it. but judging from this video, there is plenty of pressure behind the oil getting there.
Current Vehicles
2006 Audi A8
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Great video! That's the most oil I've ever seen spraying out of a turbo.
Sorry I didn't respond to your question earlier. I think most all turbos are pressure fed oil, not by gravity.if they were gravity fed you certainly wouldn't need those expensive connectors.
bags519
Post by bags519 »
Turbo Oil return rubber/plastic seal on the oil pipe into the block was the culprit. I have a video I'll throw up later it needs edited just too long.
Can't believe it could throw so much oil. It dropped three quarts out on my initial test drive after getting everything put together.
Off to the dealer tomorrow to pick up the seal and button this up!
Current Vehicles
2006 Audi A8
...but for a copper washer, the Swedish kingdom is preserved....
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 12 times
Been thanked: 5 times
Post by 850TurboTurtle »
Well, at least you know that your oil pump is working well!
850TurboTurtle
I cracked my thermo housing also, trying to break stuck bolts loose with an impact driver. I broke something all right! In the future I'll stick to PB blaster, heat, and time, and if necessary grind or cut the bolt head off.
