POLL: When did your odometer fail?
Kuhnman
- Year and Model: 1998 V70 AWD
Hi everyone. I work at a small repair shop and specialize in Volvos with a small Volvo auto wrecker out back. I've replaced the small rubber gear inside the 850 odometers several times now. I think my boss has been getting them from the dealer but if not, they come from Worldpac. About 50 bucks Canadian and it comes with new dash lights as a kit. You remove the cluster and remove the odometer assembly. Remove the electric motor on the side and the tiny gear will be just underneath it. It's about 2 - 2.5mm in diameter and you'll see right away that one or two teeth will be bent over. I would go into more depth with pics and so on but I just don't have much time, sorry. Feel free to ask any questions if you like. Also I apologize if this was already explained to everyone somewhere. Love my 98' V70XC!
Mine just failed yesterday @ 82,000 miles. I just need to order that gear and get it going again. Should be a fun project!
1997 854R
IPD Intake
Ported/Polished Intake Manifold w/3" Throttle Body
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
- Has thanked: 2864 times
- Been thanked: 1332 times
82k miles on a '97! Low! (Not talking about the odo, but rather the Volvo itself.)
Its really nice and I plan on keeping it forever this time. My last R (98 V70R Saffron) I sold after getting scared about a transmission failure when I hit 150k about 5 years ago.
1997 854R
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
Kuhnman
Hey everyone, I'm sorry I miss informed you about where to get the odometer kit. I found out we get them from a shop in Surrey B.C. (Vancouver area) called Ed Schram Motors Ltd. They get the kits out of the states, not sure from where. Here's their web addy. More info when I get it. I Hope this helps you folks.
http://www.edschrammotors.com/Home/Welcome.html
matthew1 wrote:If it's failed two or more times, please vote for the first incident.
211k.
Replaced both gears over the weekend.
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- Has thanked: 1611 times
- Been thanked: 4072 times
Mean failure at 138k
Mode at 125k
Sample size 31, so statistics are pretty good
Mode at 125k
- Has thanked: 311 times
- Been thanked: 818 times
I am curious about the meaning of this statistic; why is it reasonable to ignore the more than 1/3 of the odo gears in the survey, that haven't even failed? In other words, I can't really do much with "there is a 63% chance the gear fails, and if it does then it happens on average at about 140k." I will admit however, that the data are counter to my previous assumption, which was "they all fail in the first 15 years or so."
Seems biased to just take the mean of the failed gears, and ignore the ones still clicking away. Maybe you would want to know the mileage on the non-failures, add up all the miles, then get a frequency (miles / failure). You could even do that now by assuming the average mileage on intact gears is the same as the average mileage on failed gears (about 140k, it's a flawed guess but at least is based on something). Just food for thought ...
hmmm I also wonder how many of these data points are from x70s vs. 850s, and how the models are distributed. Might be interesting.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Should all be 850s. The x70's just dont fail. They're digital, run from the ABS module.hmmm I also wonder how many of these data points are from x70s vs. 850s, and how the models are distributed. Might be interesting.
'98 S70 T5
2016 Chevy Cruze Premier
Oh, right! The poll should just be 850s, I wonder if the bulk of those "still working" are indeed x70s.
- 26 Replies
- 10299 Views
Last post by wizechatmgr
- 2051 Views
Last post by Dmck
- 1581 Views
Last post by Matty Moo
- 80 Replies
- 18739 Views
Last post by befarrer
- 5430 Views
