1995 850 transmission swap with 1998 S70
- Year and Model: Many Volvos
- Been thanked: 76 times
Good to know it is a S70 and not a C70, I got to revise the response.
The s70 should have a 4 speed it will pretty much bolt up and be fine. The '95 had a Vehicle Speed Sensor on the transmission and that was removed on the '98 and vehicle speed was derived from the ABS module and the wheel sensors. I'm not sure if the mounting hole for the VSS remained on the later versions of the transmission or not. My guess is that it did and you can swap the '95 VSS from the old transmission to the replacement transmission. Jimmy57 will know for sure.
