Hello , I replaced a badly leaking seal on the passenger side, but still have a slight leak .
I was very careful to try and not to damage the seal and I have it flush in the housing . Lubed it with ATF inside and out and the axle slid right in . This isn't the first seal I have ever mounted , but am I missing something here ?. Thank you , Bruce
1998 v70 leaky axle shaft seal
- Year and Model: Many Volvos
- Been thanked: 76 times
Was the axle recently changed? I had a leak problem on one of mine after I replaced the axle so I replaced the seal and it continued to leak. The cheap axle itself turned out to be the problem, it had a slightly smaller diameter than the original axle.
- Been thanked: 504 times
Options:
1. Slight Leak: just watch it and top up as needed.
2. Change the axle: not necessary b/c another one may have the shaft re-machined anyway.
3. Different seal: this may be an option. Search SKF online catalogue and look for a seal with:
- Same "bore" dimension.
- Slightly smaller "shaft" dimension so it is a tighter fit.
- Has thanked: 312 times
- Been thanked: 818 times
If you know it is a cheap reman axle, I wouldn't mess with it I would replace it with a factory one, where you live it should be easy to get one from the junkyard.
Cyman
- Year and Model: 1997
I have the exact same problem.
I had to replace the U-Joint and the old seal started leaking after I put the axle back into place. Replaced the seal quite meticulously making sure not to pinch it, keeping it from going in slanted, etc. The new seal ended up leaking almost as much as the old one did. However, I payed close attention to my ATF levels during a 600 road trip and I don't think it's leaking much on the road. I didn't have to add any fluid at all. Also, once I got home it seemed like the leak was getting better for some reason (?) I leave maybe 4-6 drops of atf on the road every time I park the car.
I was going to try and fiddle with the seal a little bit more this weekend to see if I can get a better fitment.
Good Luck on your fix!
Just to give you an example, SKF 15737 seal has:
O.D. = 2.489
Shaft = 1.575
The point is to find a seal that has a tighter shaft side, maybe 1.40 or so. Look up SKF seal on the online catalog:
http://www.skf.com/binary/12-66340/457010.pdf
O.D. = 2.489
Shaft = 1.575
frisky99
- Year and Model: 1998 v70
- Has thanked: 6 times
Thanks to all that responded . Since the leak is minor and I still have a vibration through the steering wheel ,I may be replacing the axle anyway. Nothing felt when braking , no bearing problems apparent , tires balanced I'm thinking axle. I noticed a hop on that axle when I had the car up on stands .
Thanks again , Bruce
- 9 Replies
- 1139 Views
Last post by BlackBart
- 11 Replies
- 6600 Views
Last post by CEBirnley
- 3620 Views
Last post by bluesguys80
- 5407 Views
Last post by SuperHerman
- 729 Views
