1998 v70 leaky axle shaft seal
frisky99
Year and Model: 1998 v70
Has thanked: 6 times
Post by frisky99 »
Hello , I replaced a badly leaking seal on the passenger side, but still have a slight leak .
I was very careful to try and not to damage the seal and I have it flush in the housing . Lubed it with ATF inside and out and the axle slid right in . This isn't the first seal I have ever mounted , but am I missing something here ?. Thank you , Bruce
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Seems like you did a careful installation. Are you sure it's the right seal? OEM by any chance?
frisky99
Post by frisky99 »
Volvo Axle Seal - Corteco 6843112 from Eeuroparts . Sure looked good . Never had a problem with seals , gaskets etc,. from them when I used to order parts for my old Saabs. Bruce
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Was the axle recently changed? I had a leak problem on one of mine after I replaced the axle so I replaced the seal and it continued to leak. The cheap axle itself turned out to be the problem, it had a slightly smaller diameter than the original axle.
frisky99
Post by frisky99 »
yes, there was a cheap reman on it when I bought it . Was going to replace it since it has a slight hop that I think is the cause of my vibration over 60-65 mph. Thanks you Lee , Bruce
Been thanked: 504 times
Post by cn90 »
Options:
1. Slight Leak: just watch it and top up as needed.
2. Change the axle: not necessary b/c another one may have the shaft re-machined anyway.
3. Different seal: this may be an option. Search SKF online catalogue and look for a seal with:
- Same "bore" dimension.
- Slightly smaller "shaft" dimension so it is a tighter fit.
Has thanked: 312 times
Been thanked: 818 times
If you know it is a cheap reman axle, I wouldn't mess with it I would replace it with a factory one, where you live it should be easy to get one from the junkyard.
Cyman
Year and Model: 1997
Post by Cyman »
I have the exact same problem.
I had to replace the U-Joint and the old seal started leaking after I put the axle back into place. Replaced the seal quite meticulously making sure not to pinch it, keeping it from going in slanted, etc. The new seal ended up leaking almost as much as the old one did. However, I payed close attention to my ATF levels during a 600 road trip and I don't think it's leaking much on the road. I didn't have to add any fluid at all. Also, once I got home it seemed like the leak was getting better for some reason (?) I leave maybe 4-6 drops of atf on the road every time I park the car.
I was going to try and fiddle with the seal a little bit more this weekend to see if I can get a better fitment.
Good Luck on your fix!
Post by cn90 »
Just to give you an example, SKF 15737 seal has:
O.D. = 2.489
Shaft = 1.575
The point is to find a seal that has a tighter shaft side, maybe 1.40 or so. Look up SKF seal on the online catalog:
http://www.skf.com/binary/12-66340/457010.pdf
frisky99
Post by frisky99 »
Thanks to all that responded . Since the leak is minor and I still have a vibration through the steering wheel ,I may be replacing the axle anyway. Nothing felt when braking , no bearing problems apparent , tires balanced I'm thinking axle. I noticed a hop on that axle when I had the car up on stands .
Thanks again , Bruce
