How to change manual TRANS Fluid
JRL
- Year and Model: Several
- Been thanked: 16 times
Use Volvo fluid or the synthetic ATF equivilent (off the numbers on the bottle)
REDLINE works well
REDLINE works well
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
There should be a drain plug and a fill plug. Drain the old fluid out the drain plug in the bottom of the transmission and then refill the transmission until the fluid is at the threads of the fill screw.
As for fluid, I always liked royal purple or red line.
- Year and Model: Many Volvos
- Been thanked: 76 times
There are two plugs on the left hand side of the transmission. The lower plug will drain the transmission and the upper plug is used to fill it. Just fill the transmission until the fluid runs out of the bottom of the upper plug. As I recall you will need a 22mm wrench to remove the plugs.
The Volvo fluid is stupid expensive and I tried to cheap out with the slightly less stupid expensive Royal Purple that claimed it was GL-4 compatible. In my case the shifting is kinda "notchy" until the system heats up. I'm getting ready to bite the bullet and buy the real Volvo stuff for mine.
I realize this is an older thread, but I felt I should chime in on this as I just ordered my tranny oil after spending an hour verifying the right stuff to use. I am going Volvo brand, and this is where it got a bit confusing. The guys at my local shop (solid, dependable and knowledgeable) said for my car: 99 S70 T5 Manual Trans to use Volvo #31280771. I went online to check it out. On IDP's website it said that this would not "fit" my car and recommended Volvo #1161745. "interesting" I thought. So I did a bit more research and found this discussion on a UK Volvo forum: http://www.volvoforums.org.uk/archive/i ... 47127.html. If you read through this discussion the upshot is 31280771 is the oil to use on a 98/99 S70 T5 manual tranny. I am not faulting IPD here, I guess that this is a word of warning to do your homework. Manual transmissions on these guys are the exception so there is not as much info out there for us. If anybody has a differing or confirming experience regarding the proper transmission fluid for T5M's please chime in.
- Has thanked: 2858 times
- Been thanked: 1332 times
Manuals are such a small % of the P80 line in the US (2%? 3%), the knowledge on things like part #s is going to be... scattered. Not defending the small, reputable shop you went to, just saying based on reading MVS.
I'll help. Wanna do this at my dad's on Sunday?
Maybe something got lost in the translation given my wordy response. The conclusion that I arrived at was that the garage was right and IPD's website was wrong regarding manual transmission fluid for these cars. Go local knowledge! So the answer is: Volvo Manual Transmission Fluid # 31280771. But as info is spotty it would be good it one of the vets who owns one of these cars could sound off on this.
Unfortunately, my order won't arrive until next week, but I plan to do my door stop and change out the spark plugs if you are down. Let me know!
I have also done the legwork on this in AUS where manuals are very rare.
After speaking to reps from Fuchs. Motul, Shell, Amsoil, Elf.....I found out that the only listed compatiable is Castrol Syntrans 75-85. Was recommended I call them by local Volvo dealership. Something about Castrol were the preferred suppliers when these were produced. Was also told by all reps that suppliers are not allowed to list any fluids without the ok from car maker. So far so good with new Castrol fluid in, only changed due to new clutch.
I can't let this one go until I have a suitable answer. So after more digging here is what I have; according to IPD's website Volvo manual transmission fluid #1161745 is the proper oil to use in a 98 to 2001 M56 manual transmission and Volvo manual transmission fluid #31280771 is the proper oil to use in 2001 and on M56 manual transmissions. Did the M56 change between years? Am I ok to use fluid #31280771? This is what my mechanic recommended to me and what he and his friends use in their M56 manual transmissions so i am leaning towards this. Please help sort out this mystery!
- 31280771.jpg (75.77 KiB) Viewed 5987 times
- 1161745
- 1161745.jpg (122.45 KiB) Viewed 5987 times
- 23 Replies
- 3832 Views
Last post by 98v70dad
- 19 Replies
- 5138 Views
Last post by erikv11
- 514 Views
Last post by kcodyjr
- 11 Replies
- 6629 Views
Last post by kaneelschep
- 2326 Views
Last post by cn90
