1995 850 t5-R
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
polskamafia mjl
Has thanked: 10 times
Been thanked: 9 times
1995 850 t5-R
Post by polskamafia mjl »
2011 Aug - Oil Change (Mobil 1)
Oil Filter (Mann)
polskamafia mjl
Re: 1995 850 t5-R
May 3, 2013 - 207,783 miles
Timing Belt
Water Pump
Tensioner
Tensioner Roller
Idler Roller
Serp Belt
Air Filter
Cabin Air Filter
Fuel Filter
Spark Plugs
Wires
Rotor
Cap
Silicone Radiator Hoses
polskamafia mjl
Re: 1995 850 t5-R
June 6, 2013 - 207,981mi
PCV system replaced
OEM Volvo hardline substituted for 5/8" ID heater hose
Thermal protection on injector wiring replaced
polskamafia mjl
Re: 1995 850 t5-R
June 14, 2013 - 208,074mi
Oil Change
Mobil Super 5W-30 (Dino Oil)
Oil cooler line separated from radiator; lost almost all oil
Filled with Mobil Super 10W-40 (Dino Oil)
Reused old clip and secured with zip tie
Drain and fill using Mobil 1 Synthetic ATF
Drained 4 qts
polskamafia mjl
Re: 1995 850 t5-R
June 25, 2013 - 208,406mi
Replaced tires
205/50R-16 Hankook Ventus V4 ES H105 XL
polskamafia mjl
Re: 1995 850 t5-R
July 5, 2013 - 208, 687
Work done at Willowbank Auto in Bellefonte, PA
New Mann Filter
Oil Change
Replaced thermostat housing bolts w/ new Volvo bolts
Diagnosed coolant leak at waterpump
polskamafia mjl
Re: 1995 850 t5-R
July 9, 2013 - 208,827mi
Replaced ECT sensor with OEM Volvo ECT sensor
-Anti-Seize on threads
Installed new Whaler 90deg T-Stat
-Upon removing T-Stat Housing I realized the previous owner had completely removed the T-Stat.
Only the gasket was there.
Tightened hose clamps on radiator hoses
Applied anti-seize liberally to T-stat housing bolts and re-installed them
Refilled with 50/50 mix of Super Tech coolant and distilled water
polskamafia mjl
Re: 1995 850 t5-R
July 18, 2013 - 209,115mi
Replaced electrical portion of ignition switch
Replaced dimmer switch
Replaced left turn signal stalk; tested cruise control but there was no improvement, replaced the old turn signal stalk
Replaced cup holder assembly beneath center console lid
polskamafia mjl
Re: 1995 850 t5-R
July 27, 2013 - 209,199mi
Replaced entire OBD1 box with used one from junk yard
polskamafia mjl
Re: 1995 850 t5-R
August 10, 2013 - 209,639mi
Removed sagging headliner
