1995 Volvo 850 GLT Starting Problems
N_Lights1
Year and Model:
Post by N_Lights1 »
Intermittent starting problems. Removed the battery, took it in and it checked out OK. Checked and cleaned connections. Have all dashboard lights, but no detectable clicking sound when the ignition is turned. Lights dim a little, making me think power is getting to the solenoid, but not to the starter. My inclination is to start with replacing the starter solenoid.
Any other ideas or suggestions?
Thanks,
N_Lights1
N_Lights1
Year and Model:
Post by N_Lights1 »
One other item of note (see previous post on same topic). When the car does start, there is this lingering noise of something still spinning (from inside the car, it sounds like the fan blades tinging on something - but no, it's not the electric fan). From the engine bay, it sounds like it is coming from the back of the motor, down low. If the starter is not disengaging immediately, is this more likely to mean bad starter than bad solenoid (as in my previous post)?
Car has ~130k miles. Have owned it for just over two years.
Thanks,
N_Lights1
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Before replacing anything thoroughly clean the battery leads and connections, including where the earth (ground) lead is connected to the body, the starter/solenoid wiring and the engine/transmission earth strap.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Volvo850Racer
Year and Model:
Post by Volvo850Racer »
You might want to pull the codes from port 2. I had a bugger of a time finding that port 6 was merged with port 2. Any how I had the same problem and it tured out to be the CMP. I bought it from eeuroparts.com. Once I replaced it I reset the code and it is been fine sisce
Mark
95 850GLT Wagon 84k Sway bar mod
94 850 resurrected from salvage Sold
93 850GLT Volvo bought it back
86 740GLT Traded
