p0410 97 960 question
Jonc123
Year and Model: 98 v70, 87 240,
Post by Jonc123 »
Hey I have a 1997 960 that is throwing the p0410 code. I checked all the fuses and relays and they are all fine. However the pump itself is not getting voltage....It will work if i jump it directly from the battery. Can anyone help me as to where the next place I should look? thanks.
Has thanked: 1613 times
Been thanked: 4078 times
Discussion of the P0410 code (Secondary AIr System problem) is here
https://www.matthewsvolvosite.com/forums ... php?p=8952
Jonc123
Post by Jonc123 »
Yes I did as much research as I could before posting. But none of that discussion helped. I am trying to get voltage to the air pump. The relay and fuses are good. Pump works when jumped... Will there only be voltage on start up? Thanks
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
Check the control valve. There should be vacuum hoses coming out of then connections to the ECU.
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The system only works for up to 50 seconds on cold starts.
How do you know the relay is good?
