850 radiator replacement
- Has thanked: 1613 times
- Been thanked: 4077 times
No. Turbo means no intercooler, which makes this job much easier, maybe 2 hours or so?
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I replaced my radiator about six months ago. It was a two day job for me, but I took my time. I wrote up a little guide on how to do it...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I replaced it with a new Volvo radiator.
It takes time and patience, good to have your favorite FM station playing.
An opportune time to restore the heating and cooling components, hoses and AFT cooler lines.
It will cut the PCV job to 1/2 the time.
Use recommended tools and steps, else costly and painful.
neworleans
- Year and Model: 2007 S60R
FCP has a DIY video for this.
Check out this link
Check out this link
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 2215 times
- Been thanked: 1853 times
I've got the radiator out of my 98 V70XC (turbo engine) and it is way more challenging than the NA motor in the 850 (did that one last year).
It is common for the radiator to leak at the plastic to aluminium join. My one and only recommendation is I only use Volvo radiators. Haven't bought one recently, but I used aftermarket versions and have a hell of a time getting the top hose to remain leak free. The difference is the Volvo radiators have a brass tube in them that stops the plastic squishing out of round. Hopefully Volvo rads are still made this way and they are not buying aftermarket crap like several of the parts I have bought from them recently, and they have the cheek to charge stupid prices for them. They fit well, but you might want to think about replacing the rubber bushes that the rad sits on where they bolt to the chassis rails.
Like the others have said, it is not really hard, but take your time and take advantage to check/replace other parts like hoses and thermostat while you are in there.
Good luck!
Good luck!
Alldata reports 2.6 hours for radiator change on a 1999 auto turbo.
Your NA should be easier.
dec913
- Year and Model: 850 2.5s Estate (96)
The bolts that attach the radiator to the body have sheared the nut from the bodywork, I've cut them off and botched it for the min. but any suggestion for a permanent fix???
Also is the bottom hose the same as for a v70?
- jreed
Can you post a picture of the broken area? I wonder if you can relocate the nuts to the other side of the flange, tack weld or epoxy them in place, and then pass the bolts through the flange and tighten them against the nuts?
- 3661 Views
Last post by t3yf5g
- 9 Replies
- 7207 Views
Last post by jalwlb
- 289 Views
Last post by volvolugnut
- 2014 Views
Last post by rspi
- 359 Views
