2004 V70 Erratic shifting when warm ? could be B4 servo ?
Hi guys! I got a 2004 Volvo V70 2wd non turbo 157K miles, the car drives great when cold but once I drive it for 10 miles gets warm and nice, transmission starts to shift real hard, sometimes It goes into neutral and really hard down shift. there are no codes at all, took the car to the dealer, they said the software needs to be updated, they did the update but the problem is the same! could it be B4 servo? fluid looks nice and pink. did my transmission give up ? any help and advice would be appreciated!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Valve body is likely not in the best condition. If you don't want to replace it, try additional transmission oil cooler. That helped to wife's '02 V70, shifts perfectly when cold and hot (perfect as can be for 12y old automatic transmission), better than '05 XC70.
Hayden OC-1401 in the middle of a process:
Hey Swedes, this must be a standard equipment!
- 952 Views
Last post by oragex
- 3654 Views
Last post by 93ForMe
- 995 Views
Last post by Jlewis2005
- 1117 Views
Last post by dux02v70
- 674 Views
Last post by skloon
