hello all,
just a quick question, I had the manifold off last summer in suspicion that it was clogged and to my disappointment it was not, so I put it all back together and the car just still to this day doesn
PCV question
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Engine running: pull the dip stick...should be suction there. Same thing if you take the oil filler cap off. If you're getting excessive blow-by, your turbo could have a "loose" seal in it. This isn't necessarily a horrible issue but it will get worse as time goes on until it isn't very effective anymore. Just clean your throttle body every 6 months or so and try not to worry about it that much.
- 1651 Views
Last post by rspi
- 14 Replies
- 2089 Views
Last post by woodycaldercloggs
- 9 Replies
- 1487 Views
Last post by PatternFlyer
- 15 Replies
- 2238 Views
Last post by MadeInJapan
- 18 Replies
- 2973 Views
Last post by Clemens
