97 850 GLT AC Only Working On One Side
prienzo
Year and Model: S60R, 2007
Post by prienzo »
Hey guys, 97 850 GLT, 242k miles. It was in the 80s last week and I turned on the air conditioning only to find it was blowing hot air :evil: I realized though that it is only blowing hot out of the driver's side. The passenger side is blowing ice cold.
Tried searching, but couldn't really find anything definite. What should I be checking out here?
TIA
-Patrick
1993 850 GLT - Totaled
1998 S70 GLT - Sold
1999 Volvo V70XC - Sold
1997 850 GLT - Daily
2007 S60R - Tastefully modified and now the weekend car :)
Been thanked: 4068 times
try swapping driving with your partner. S/he might be hotter than you..
OK - seriously - the Volvo AC uses two motors under the dash to change the mix (hot cold) of the driver and passenger air flow, independently. The good news is the expensive parts of your AC are working since you have cold on one side. All that is wrong is the blend door motor (Electronic Climate Control) or the cable (Manual Climate Control) on the driver side.
Ill try find some repair links to guide you.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There is some good troubleshooting information on the " half hot -- half cold" ECC problem here:
Testing a damper motor with a 9V battery
https://www.matthewsvolvosite.com/forums ... 8&p=254621
Fixing broken shafts on the damper motors:
https://www.matthewsvolvosite.com/forums ... =1&t=44337
https://www.matthewsvolvosite.com/forums ... =1&t=31314
Thanks jreed. Still recovering from a long RTW biz trip
prienzo
Post by prienzo »
Thanks guys, I'll look into the motors.
1998 S70 GLT - Sold
