The needle has been like that for over a year. On a compass, it would be a degree or two, just enough to notice it's not exactly due East. I wonder if it's the t-stat. I know I changed it but don't recall if I used an after market or OEM.
Should I be concerned?
96 850 temp gauge slightly above 3:00 o'clock
- Year and Model: Many Volvos
- Been thanked: 76 times
My Platinum has always read about a needle width high, even after changing the ECT sensor, the thermostat, the radiator and the water pump (not all at the same time, just as a part of other maintenance or repairs) it has never moved. I guess some of them just read a bit high.
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Mine too, as per Lee's post. I also changed the same parts on my old turbo wagon, and it always read high. Probably nothing to worry about!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
- Been thanked: 504 times
Assuming the thermostat is new, every dash gauge is a bit different.
My tstat is Wahler and is brand new, but the gauge is a tiny tiny bit (about 1mm) below 3:00 o'clock.
I'd not worry about it.
jrobles007
- Year and Model: 850 NA, 1994
I had the same concern, after replacing water pump & thermostat. After researching coolant information on this site (for example Coolant antifreeze volvo recommendatiosn ) I realized I was running the wrong coolant. I had a bottle of Peak flush and completed a coolant flush of the engine following the instructions on the bottle. I used distiller water and then filled her up with Zerex G05. There was a lot of sludge flushed out and the car runs noticeably cooler. Now my temp needle was more like at the 2 o'clock position. It is now at 3 o'clock and will go slightly above it on hot days. It stays constant even with AC on. I did this in spring of this year and have noticed some remains of the orange sludge in the overflow tank, but the car still runs cooler than before. I plan to replace coolant again next spring.
JR
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The simplest thing to do is read live data with an OBD2 reader. These needles are taken off most of the time when people do the ODO gear repair, if not put back on just right, it will be off when it comes to temp. My guess is that there is nothing to worry about but read the live data to be sure.
- 12 Replies
- 2072 Views
Last post by regent
- 1372 Views
Last post by FLXC90
- 983 Views
Last post by kanona40
- 784 Views
Last post by volvolugnut
- 16 Replies
- 1403 Views
Last post by Clemens
