99 s70 2.4 , Small coolant leak radiator !
Hey guys , 99 s70 2.4 , small coolant leak radiator ! Don't believe its coming from the tank seal... It drips about a 6 - 12 oz's overnight , and is intermittent . Thinking of using Bars Aluminum Stop leak or Prestone super aluminum stop leak with the Kevlar particles . Any recommends for temp fix !!
JDS60R
- Been thanked: 3 times
Best to just pull it and drop in a Nissens from FCP. Temp fixes cause an even more expensive issue about 20% of the time. Sometimes after the rad was replaced as tech did not flush the system to get the particles out.
Your call
Best Wishes,
John
Your call
Best Wishes,
John
Retired
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Replace the rad or the hoses. Figure out which is leaking.
Don't play coolant roulette. It's not worth it.
- Has thanked: 1614 times
- Been thanked: 4078 times
Just remember the stop leak product means 2000 USd for head later.
- rspi
Contact rspi..
Then park it. This means that you can't afford to drive. Radiators at a salvage yard are about $40. There are a lot of them in there that are good and some that are newish.nonturbo wrote: no $$ for radiator now, have to replace later.
ericbs1975
- Year and Model: S70 GLT, 2000
I replaced mine a couple of weeks ago. Got one new off ebay for about $80 (including shipping). Mine had a crack in the seam on the plastic side of the radiator on the passenger side. It's not too bad of a job. I did it in a few hours and I am a horrible mechanic. If you poke around a bit, many will recommend you replace the green clips and o-rings for the transmission cooler lines where they connect. I'd agree with them, the green clips get real brittle and if they crack you could have one pop out while under pressure. Here's a link to the kit from IPD: http://www.ipdusa.com/products/5777/114 ... l-kit-1999
ericbs1975
Here's this one: http://www.ebay.com/itm/BRAND-NEW-QUALI ... aa&vxp=mtr
Do your due diligence and see if there are any reviews. These guys seem legit, and it is warrantied. $80 shipped isn't too bad. Mine was similar and seemed pretty solid, but your mileage may vary.
- 1430 Views
Last post by GBS
- 394 Views
- 1702 Views
- 956 Views
Last post by benpineapple
- 16 Replies
- 3417 Views
Last post by jreed
