Shortly after posting on here about replacing my hood latch (which hadn't happened yet), my hood ended up blowing back over my windshield, shattered it, bent the hood hinges, etc. Now that I've replaced my windshield, I need a new hood. How difficult should I expect it to be to replace myself? I haven't been able to find anything online as far as videos or anything about replacing a hood for a Volvo.
Thanks
JJ
Hood replacement
ericbs1975
- Year and Model: S70 GLT, 2000
While I haven't done it myself, the process is in the Chilton's manual (72302). It only lists like 6 steps: basically disconnect any wires and tube, unbolt the hood from the hinges, then remove the hinges. The book points out the bolts you need to deal with. It seems where the trouble comes in is in aligning the new hood to the car (the book mentions marking where the hinge and hood meet). Sorry this is probably not the step by step tutorial you are looking for, hopefully it helps somewhat. If you can get the Chilton's book it is worth it.
Glad to see you are safe after that experience. What you described sounds scary!
-Eric
-Eric
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I'll look a little closer to the hinges today. There was just 2 or 3 bolts on the 960, don't think the 850 will be much different.
Did you find this video?
Ben850
- Been thanked: 7 times
I can show you an example and get in depth with the procedure if you have questions. Look at my wagon in the maintenance log here,
https://www.matthewsvolvosite.com/forums ... 35&t=56550
The previous owner had done that, (the hood flip). It involves new hinges, fender removal, and what I had done with a rubber mallet. I had used a wooden plank with mallet to smooth the corners of the bent hood after installing the scrap hinges. These were approx. $8. ea. which I sprayed white to match my car.
Get back with me if you need. Good luck.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- rspi
Contact rspi..
Glad my 960 didn't require finder removal.
Ben850
Thanks for posting that video Robert. I did not want to bend my fenders while removing the hinges. I had also needed to remove the bumper and did all at the same time.
My log shows what I had done.
- osman
- Year and Model: 2002 c70 hardtop
The fenders only need to come off if you are replacing the hood and the hinges otherwise just the hood is rather simple. Only thing is you have technically 3 hood latches one over each headlight that work from the cable and actually hold down the hood then the third manual one which only is a handle to pull up the hood but must function, it is often repaired with a zip tie or wire hanger.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
Ben850
When the hood flies, it destroys the hinges. They can be bent back into shape, but replacing is easier. Even if removing the fenders is needed. It is.osman wrote:The fenders only need to come off if you are replacing the hood and the hinges otherwise just the hood is rather simple. Only thing is you have technically 3 hood latches one over each headlight that work from the cable and actually hold down the hood then the third manual one which only is a handle to pull up the hood but must function, it is often repaired with a zip tie or wire hanger.
Trust me.
Edit: Use an 1/8" drill, or there about to remove the rivets from the fender liner. It is quick and easy.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
We just replaced a hood and hinges. I wouldn't even waste my time attempting to fix the bent ones.
Just like he said, the hardest part was getting the spring on the new hinges..other than that it was relatively easy. It helps to have another person help with the hood.
I think the two of us did it in 90 minutes.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Ben850
Hey Matty,Matty Moo wrote:We just replaced a hood and hinges. I wouldn't even waste my time attempting to fix the bent ones.
Correct Sir.
I wanted to reinforce, you will likely need a helper to get the springs on.
I had used a pry bar while a friend held the hinge loosely bolted for wiggle room.
Care is important. The guy that works with me has no fear, has been doing these things for a while.
He is a crazy musician friend of mine so be careful.
- 32 Replies
- 5830 Views
Last post by MrAl
- 1874 Views
Last post by cn90
- 2606 Views
Last post by tekline
- 1088 Views
Last post by Herb Goltz
- 2448 Views
Last post by Thunderbox
