another pcv question.
I have a 1999 Volvo s70 t5 and it is showing signs of needing a pcv sytem change, it has oil on the top of the engine, I live in Canada so it might be a week or 2 before I get the parts and a few weeks before I get the time to do the job. I was wondering if I took the dipstick out and put a hose on it running to a filter if it would prevent any further damage until I get it fixed right.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
It is likely that the PCV is clogged at this point, you are also looking at replacing front and rear intake and exhaust cam seals. Ignition rotor, spark plug, and wires in next 12 months.bigdawg74 wrote:I have a 1999 Volvo s70 t5 and it is showing signs of needing a pcv sytem change, it has oil on the top of the engine, I live in Canada so it might be a week or 2 before I get the parts and a few weeks before I get the time to do the job. I was wondering if I took the dipstick out and put a hose on it running to a filter if it would prevent any further damage until I get it fixed right.
Or it could just be the weak rubber seal in oil cap. Replace it first for few bucks.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
What makes you think it is in need of service, other than the oil on top of the motor?
The glove test is at about 6:00 in this video.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Hello. Where is the oil on top of engine at ? I had oil leaking from the top of mine running down the back on drivers side. thought I needed pcv service. Come to find out the oil was leaking under sparkplug cover , pooling up and leaking. The leak was caused by a loose 10mm bolt on top of valve cover that was only finger tight. Take a look .
it is the pcv that is pluged, what I would like to know is if there is something that I can do to prevent further damage until I receive the parts to fix it right because I still need the car to get to work ,I will be able to do the job in about 2 weeks.i pulled the timing cover off to check what tensioner I haves and there was no oil on the timing belt,
I was looking at the car thismorning anf found what appears to be a broken vacuum line coming off of the intake on the passenger side of the carthat seems to curve and head under the intake. is this pcv related?
JRL
- Year and Model: Several
- Been thanked: 16 times
Yes
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
bigdawg74 wrote:I was looking at the car thismorning anf found what appears to be a broken vacuum line coming off of the intake on the passenger side of the carthat seems to curve and head under the intake. is this pcv related?
It provides vacuum at idle to the PCV hose @ the turbo.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
Contact rspi..
If you don't have an oil seal leak you are probably ok. Just don't put your foot in it and replace the PCV as soon as you can.
the garage that I work at is also a autoparts so I have access to every size of hose and copper tubing you can get and tons of elbows and I have a new intake gasket so Saturday I am going to pull it apart and see were it is plugged .
