The I Worked on My Car Today Thread
This topic is in the MVS Volvo Repair Database » 2000 V70 Tailgate Trim Rattle Fix
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
Redid my ABS module repair, which had failed on me after not many miles. The ABS light would usually be on after a little driving, and when not on, sometimes the ABS would kick in during non-skidding braking. So I re-did the soldering and did a more thorough job on the two wires from the module to the pump---the insulation had rotted away. This time I cut off the plastic cap on the pump so that I could get to those wires where they enter the pump; I wrapped them with electrical tape. An initial test drive was promising; the light stayed off and the ABS kicked in appropriately when braking hard with a tire over a manhole cover.
1996 850 Turbo Wagon
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Today I met a forum member in my area with a 99 T5 S70 255K and helped him replace/repair his dash mounts, installed new front seats, and replaced recirc motor. Started at 11 AM finished at 7.
Did I win? I hate doing dash mounts.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
taffbouncer
Year and Model: V70 2055
Post by taffbouncer »
thanks Mike - hadn't considered the tailgate
By the way - I have ditched the crappy amber bulbs and fitted silvered indicator (turn) bulbs - still glow amber. Get a better look on the front and rear clusters. £8 a pair in Halfords. Be sure to get the off centre pins on the bulbs - there are two types
PDLarson
Year and Model: V70XC, 1999
Post by PDLarson »
Replaced the fuel filter. I had a heck of a time with removing the fuel lines. I finally got some better light in there and saw there are some plastic rings below the metal parts of the connectors, those are what need to be moved up into the connector to remove the fuel lines. I hated hacking up my car but it runs now
Winter in Montana, AKA: XCs are great!
erikv11 wrote:PDLarson has been spot on.
1999 V70XC / Mostly stock under the hood / Several cosmetic mods inside and out
2008 XC90 V8
Carbon15
Year and Model: 94 850 Turbo
Post by Carbon15 »
Not so much today but the last two weekends. Transferred the front suspension, control arms and flex brake line from the 98 S 70 to 94 T 5, Last weekend transferred E brake cable and installed new pads. Also had to manufacture and install passenger side rocker panel.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
Been thanked: 4068 times
Dived into my P80 today for a long week of work in the cool mornings
PCV overhaul...never done on this car, 170k miles
Oil change
Coolant change
ETM cleaning
IPD turbo boost spring
New vacuum hoses.
New clamps on induction system
Ben850
Been thanked: 7 times
Post by Ben850 »
I detailed my wagon at my friends airport hangar. I worked on his 1963 Lincoln Continental.
I installed a Holly 750 in place of the original Carter. It is the manufacturers alternate recommendation.
It worked and he was very happy to have it running again.
Hangar full of RC planes and a Lincoln.
Prepping the carb, removing junk from the manifold.
the only shiny thing in there.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850 wrote:I detailed my wagon at my friends airport hangar. I worked on his 1963 Lincoln Continental.
That's a gorgeous car. I think you could fit an 850 in the trunk.
Still nibbling at my PCV and hose replacements. 30-60 minutes at a time since I have ip overseas company for three weeks.
I'm convinced the easiest way to remove OETTINGER clamps is with my favorite tool, Dr Dremel.
Trying to pick open the clamps on the small turbo hoses is absolutely nasty, with limited access for hands, tools, and back breaking to reach in the engine bay.
My OEM heater hoses are still in great shape so I will keep/ offer to someone restoring/ maintaining on a budget.
