1995 T-5R. It won't warm up while driving for some reason. It gets to about ~145-155F and it will not go past that. I have confirmed this temperature with a OBDII scanner and a laser thermometer on the aluminum coolant elbow on the top of the block.
If the car sits and idles, it will get fully warm.
I have replaced the thermostat twice (total of 3 different thermostats) and all of which have done nothing.
I would have thought it was a coolant temp sensor issue, but the laser thermometer reading on the aluminum coolant elbow pretty much confirmed the cars dash coolant temp reading and the OBDII reading. I also made sure to let the car sit and confirm with the laser thermometer that the elbow got up to temperature in correlation with the dash gauge and OBDII readout.
Any big bits of advice here? I don't truly know where to go with this. I was thinking I may unplug the radiator fans and see if for some reason they're kicking on during driving.
help!
