1988 240 New blower motor resistor not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cascadia
Year and Model: 240DL 1988
Post by cascadia »
Undertook the infamous blower motor replacement today :evil: . Dis-assembly and replacement went fine following the lead of many others. However, when I made the connections and turned on the fan I only get one setting-high. This leads me to believe that there is a problem with the resistor. The motor, resistor and switch are all brand new from ipd.
Did I miss a connection somewhere? Is it possible that the resistor is bad? Perhaps I will remove the wire terminals from the plastic connector and hook them directly to the switch-it seems loose and the wires are not fully seated inside. Any problems with this idea? Or any other suggestions?
I hope it is not the resistor as I really do not want to have to go back in there....
Thanks
kentchef54
Year and Model: 1967 122
Post by kentchef54 »
I am in the same boat, Cascadia. Did everything you did exactly. Even bought the stuff from IPD!
I have a new (had to pay for it) resistor coming and hate to tear everything apart again. I wired it according to IPD's instructions, too. Same outcome as you- just one speed.
Did you ever get yours figured out???
