It takes 9 ratchet to engage the parking brakes. Here are two photos.
Does the nut needs tightening more?
The item in circle is angled, should it be parallel to..., even when pulled? How?
Many thanks!
2001 V70XC Parking Brake Cable Adjustment
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
Normally it is adjusted at 5 ratchet teeth. Before to adjust I would check condition of cables and shoes.xHeart wrote:It takes 9 ratchet to engage the parking brakes. Here are two photos.
xHeart wrote:The item in circle is angled, should it be parallel to..., even when pulled? How?
Yes. It indicates a seized cable or something wrong with the shoes mechanism. The lining materials can separate from their supports. Damage can be expensive to repair;
http://atlanticmotorcar.com/case-studie ... rake+volvo
See the following threads for more information;
https://www.matthewsvolvosite.com/forums ... =9&t=57226
https://www.matthewsvolvosite.com/forums ... =9&t=42740
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
xHeart
I was planning on replacing rotor and pad in 60-days, now closer, 30-days.
The list of parts for rear brake service are - Zimmerman Z-coated rotors, Akebono brake pads, ATE brake shoes, Volvo shoe spring, what else?
The photo at the link shows damaged dust-plate. I will check mine this weekend.
Many thanks.
Many thanks.
DGM
The aluminum block shown in the link is a broken off part of the hub assembly. It happens when the shoes mechanism jammed inside the rotor. In these extreme cases the hub must be replaced. That's why it is good practice to inspect shoes regularly as mentioned in the link.xHeart wrote: The photo at the link shows damaged dust-plate. I will check mine this weekend.
Many thanks.
You can't go wrong with the quality parts you want to install.
In our northern climate with the salt on the road it is not uncommon to experience seized cables on parking brakes.
coflynn
- Year and Model: 2002 S60 AWD
- Been thanked: 6 times
On my car the shoe expander was seized very badly on one side. I was able to get it working again after a LOT of effort cleaning it / packing with grease. Definitely check it's moving freely and perhaps consider having spares on-hand... although it seems like lots of people have no issues with it, so I wouldn't buy it "just because".
xHeart
Do I need a tool to work with parking brake pad, spring etc?coflynn wrote:On my car the shoe expander was seized very badly on one side. I was able to get it working again after a LOT of effort cleaning it / packing with grease. Definitely check it's moving freely and perhaps consider having spares on-hand... although it seems like lots of people have no issues with it, so I wouldn't buy it "just because".
xHeart
I have the two kinds of needle nose you mentioned coflynn.coflynn wrote:I had done everything with a largish pair of needle-nose pliers. Having needle nose vice grips was also handy!
Would these have helped in any way http://www.harborfreight.com/3-piece-brake-spring-pliers-kit-97804.html?
xHeart
The procedure for replacing brake pads, rotor is familiar. But the parking brake shoe, et al. is new.
I am working on rear passenger side first, caliper is off and hung, screw holding the disc to hub is out, but the disc is not sliding out after few solid hammer knocks, visibly rusted.
After the thanksgiving break, I am back in my heated garage.
Do I heat/torch the disc, where?
The rear of the disc is exposed where calipers slides on, between 1 and 2 o'clock, rest is covered with the dust shield/plate. Is there a right place to knock for it to slide off the hub?
- 2227 Views
- 6288 Views
Last post by RosserV70
- 960 Views
Last post by 1997volvo850
- 2931 Views
- 27742 Views
Last post by OnTrack
