2006 S60 R Cupped tires
DanG
Year and Model: 2006 S60 R
Post by DanG »
I have a cupping issue with my tires. Before I replace them with a new set, I want to get a handle on the cause of the cupping. Is it a suspension issue? Will I need the tech to check my struts? What I don't want to happen is spend the $ on four expensive tires to have them cupped after 6,000 miles. Any advice would be appreciated.
Thanks,
DG
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
How is the rebound on the struts ? Just pushing down the side of the car and quickly release it, does it go up, down then stops moving? How much did the tires cost?
DanG
Post by DanG »
When I push down, it comes back up and stops moving.
The current tires are Pirelli P6.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Cupping fronts or rears? inside or outside edge or both edges?
oragex
Post by oragex »
Does it look like in the 3rd picture? Do you do launches ?
http://www.hotrodhotline.com/md/html/tires.php
DanG
Post by DanG »
Cupped on the front outside edges.
When you run your finger along the circumference of tire, you can feel it on every other tread.
DanG
Post by DanG »
In regard to the third picture, my tires aren't to that extreme. I don't know what launches are.
oragex
Post by oragex »
If it's the same on both front tires my guess it's the geometry needs to be checked.
jimmy57
Post by jimmy57 »
Yes, get alignment checked. Should be a faint amount toed out.
o2k
Year and Model: 2004 S60R
Post by o2k »
i ruined a set of tires because they were cupped.. I was just getting an alignment basically once a year.. Now I get it done 4 times a year... I have the lifetime alignment at firestone. Solved my issues.
2004 S60R GT Flash Green Atacama
