1996 850 ECC dead...bad connection at fuse box #31
Ben850
Been thanked: 7 times
Post by Ben850 »
I am speaking of my '96 Turbo Wagon.
I would be happy to get a blinking light at least, but there seems to be no power at the units.
I have swapped out three different ECC units so far. They were all salvage, but I was hoping the odds would be with me by then.
I have swapped the ignition switch,
three different power stage,
all the "J" overload relays,
the relay and the sensor at the fan,
The fan.
I wanted to try other diagnostic options. I have the Bluetooth ELM-327 OBD-II with a Samsung Galaxy 5.0 reader using the torque Pro app. It is useful, but not for ECC.
I enjoy the OBD I in my '93 for diagnostics. The flash codes are user interactive and somewhat fun.
So after reading a few threads I built my own LED flash code reader from the simplest schematic imaginable. I was a little bored and got creative with it. I built a reusable tool that stores cleanly and untangled.
Simple Schematic. Two parts. Switch and LED.
I thought of ease of operation, self contained and conveniently storable. I was inspired by looking around for something to repurpose.
The next photos should be self explanatory.
I said I was bored.
I said I was bored.
I thought through the process of events pretty well.
Paperclip cut in three pieces for leads.
Put your orders in now. I use deodorant often.
Put it in your overnight bag.
Checking Monotronic.
It works.
It works.
I like the simple things.
So it was good for checking my Monotronic ECU, and clearing the code. I only had one for rear O2 which I had replaced in May.
Unfortunately it still couldn't help me with the ECC as it will not power up.
I will look for another at the yards if we have a warm day like it was Yesterday again, but that isn't likely for a while.
In the mean time, I have a stack of new parts to take my time with over the winter. Rear calipers, four slotted rotors, Akebono pads all around, silicone coolant and turbo hoses, e-brakes, Bougicord wires, and more.
I am glad I gave as much attention to the Sedan. This will be the second Michigan winter for us.
In the mean time, I've got my head in wiring diagrams and schematics.
I am not really trying to sell these units. I was just hoping someone may be inspired to make something I can copy.
Have Fun.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
What does this do above and beyond OBD2? If your ECC would power up, would it be able to flash the ECC codes. eg 1-1-1, 2-2-1 etc for troubleshooting ECC blinky lights? I've got a 98 V70 that blinks its ECC lights at turn on time. Still works but I know something is wrong.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Ben850
Post by Ben850 »
rmmagow wrote:What does this do above and beyond OBD2? If your ECC would power up, would it be able to flash the ECC codes. eg 1-1-1, 2-2-1 etc for troubleshooting ECC blinky lights? I've got a 98 V70 that blinks its ECC lights at turn on time. Still works but I know something is wrong.
It reads the specific trouble codes as in the 1-1-1 style of the OBD I under the hood used in '93 to '95 850. Not the blinking you get on your actual ECC unit in the dash, which only lets you know something is wrong.
Has thanked: 311 times
Been thanked: 817 times
What happens if you rotate the little dial at the bottom?
Ben850
Post by Ben850 »
"What happens if you rotate the little dial at the bottom?"
It does the same thing as my present ECC unit.
:lol: :lol:
You can mount it in the ECC slot until you get that one sorted out!
Been thanked: 4068 times
...the small dial will cover up the smell of the driver...
Ben850
Post by Ben850 »
abscate wrote:...the small dial will cover up the smell of the driver...
You know too much about me!
I have given some thought to this thing I have found.
taxi
Year and Model: V70 2000
Post by taxi »
I recently replaced my ECC unit due to bad dials, and on my way out of the junk yard I dropped the thing in the pavement, when I got back to work I slammed it into a door. Then I managed to put it in the car and it worked! I actually didn't think it would physically fit in the car because it had some new shapes now.. But it did, and apparently it cannot be broken by man.
I just wanted to give you my individual experience and my belief that your ECC simply is not getting volts, because you should at least get 1-1-1 from it. I would start by suspecting the ignition switch.
Have a good weekend!
Ben850
Post by Ben850 »
taxi wrote:I recently replaced my ECC unit due to bad dials, and on my way out of the junk yard I dropped the thing in the pavement, when I got back to work I slammed it into a door. Then I managed to put it in the car and it worked! I actually didn't think it would physically fit in the car because it had some new shapes now.. But it did, and apparently it cannot be broken by man.
I would like to do many of those things to the ones I have. There is a power issue, failsafe that needs to be determined.
It may be a frayed wire imbedded in a harness. I will find out!
