I would have noticed if it happend. Absolutely none of my plastics in my Volvo have been affected, just my drill! My radio face has been fine and everything is perfect, just it was bought in 1995.osman wrote:Havent you noticed "the sticky effect" on Volvo radio faces, ECC's, and window switches, It is some no slip surface when its new, then it deteriorates and looks like your surfaces are covered in sticky dirt.
I love this car, and I don't see myself selling it. I wonder how those newer Chinese Volvos are doing??
The only 4 things off the top of my head I would change are the following.
1. Driver side windshield washer spring tension is too strong for the arm, so over time it bends liftin git from the glass! I'd need to search on the forum to get the correct arm to fix that from a later Volvo. I looked into it but my local junkyard is very small, and rarely has any.
2. Better intermittent wiper system (heard a part can be bought, or used to be able to be bought to fix that)
3. The rear trunk is heavy enough to chop off a cow's head and drops like rock. The newer design in the later years is much much safer!
4. The plastic "tray" that the leather covering of the stick shift is connected to is getting loose, so in warmer temperatures (like summer) when I shift it becomes loose and the leather covering lifts up and has to be snapped back in (pain in the rear!)
