VIDA DICE, which one to buy?
VIDA DICE: What to buy?
When you connect the dice to the obd2 port, what are your LEDs doing? I have a red one at the bottom that is constantly blinking red. It's supposed to be interface to the car, and from the documentation I've read, it should blink when talking to a part of the car. I'm wondering if I have a bad unit, since mine blinks the whole time it's plugged in, regardless of whether the dice is plugged into the computer or whatever - just blinking.reverend wrote:I seem to recall that the DiCE unit requires the 12v from the ODBII port to power up, and the 5v from the USB port isn't enough.
I'm running the 2013A version in a Virtual Machine. The VM is a clean install of Windows 7 Ultimate, no updates, IE9. I threw VIDA on it and it attaches DiCE just fine from the host OS.
Came out to 20GB total, but only 9GB compressed. I found it easier to do it that way than to keep an extra computer around (which I have) just for VIDA duties. Plus it's portable. One computer dies, and I can just copy the VM to another one.
Ok, update from my end. I installed XP Mode on my Win7 Ultimate installation, and then reinstalled Vida on that, and it works magnificently! It takes longer for the virtual machine to get going, but it works no problem.
And, to confirm, the DiCE is viewable so long as it's powered, whether it's attached to the OBD2 port or not.
- Year and Model: Lots
- Been thanked: 128 times
That will involve a software download to do that. Unlicensed copies don't have that ability.KitBurger wrote:Does anyone know if it is able to access the security system so I can turn it off and install an after market one that won't give up on me in the middle of no where?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I have IBM ThinkPad (2005 LENOVO) running Windows XP, File System FAT 32, Memory 768MB, Free Disk Space 20G, and IE 6. It is Intel Centrino with Mobile Technology.
I read that many here - Regent and Ozark for sure - running VIDA DICE 2010 and 2011 variants on Windows XP.
I will use this ThinkPad for VIDA DiCE only.
What next, upgrade memory to 2GB, download and install IE-8?
Which VIDA DICE version to order - from where/who?
xHeart
Culture wrote:OEMscan on AliExpress, search for that and Yolanda. Based on XP, I would advise against DiCE Pro, just the regular one.
Found this listing http://www.aliexpress.com/item/2014-Professional-Diagnostic-Tool-Volvo-Dice-2013A-Volvo-Vida-Dice-For-All-Volvo-Car-Models-you/1612812453.html
- 7918 Views
Last post by lrock
- 16318 Views
Last post by xiaofei204716
- 799 Views
Last post by jonesg
- 10 Replies
- 19072 Views
Last post by jonesg
- 7107 Views
Last post by Klem
