1999 xc70 awd missing driveshaft
Bought the car used and the drive shaft is missing making the car only front wheel drive. What would I check for before buying a drive shaft to make it awd. Does anyone know of a shop in northern Westchester NY who could do the job. I am not a big fan of dealers.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
The AWD models had at least three different prop shaft lengths depending upon model and year so you will need to accurately measure between the two faces it bolts to. Also ensure the prop center bearing carrier bracket is still attached to the underside of the car, it sits about 3' back from the coupling on the gearbox where the prop would attach to - Mike
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
The driveshaft was taken out because the bevel drive had failed or was about to. You`ll need way more than just the drive shaft to make it AWD. You unfortunately had someone who was less than honest sell you the car.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You could be right about that, but you're making a lot of assumptions...ThommyKent wrote:The driveshaft was taken out because the bevel drive had failed or was about to. You`ll need way more than just the drive shaft to make it AWD. You unfortunately had someone who was less than honest sell you the car.
There are a ton of posts about the AWD systems in these cars. It's true
that many have been abused, especially by using mismatched tires, but
there are also folks out there that just remove the driveshaft in an attempt
to improve gas mileage. In the OP's case, it could be either of these extremes
or plenty of other things in between. You won't know what's really going on
without doing some research and spending some time checking the system out.
As stated, there are differing parts between 98, 99 and 00's. Great stuff here:
http://v70r.com/forums/topic/33058-98-0 ... ntry122715
- instarx
- Year and Model: XC70 T6 2011
And exactly how do you know that? The bearings on the shafts often fail (the front bearing mostly), and in that case it is a simple matter to replace either the entire shaft or just the bearings.ThommyKent wrote:The driveshaft was taken out because the bevel drive had failed or was about to. You`ll need way more than just the drive shaft to make it AWD. You unfortunately had someone who was less than honest sell you the car.
To the OP:
Pauloil's advice is good - call Colorado Driveshaft with your VIN. Once you have a driveshaft and mounting hardware it is a very simple job to put it in - any mechanic can to it in about 20 minutes. Of course It is possible that the driveshaft was taken out because something else was wrong, but you won't know that until you get the new shaft in.
Things that could cause the driveshaft to be taken out: Viscous Coupling (caused by running mismatched tires or incorrect towing), bevel/angle gear, and of course bad driveshaft joints. Tons of information on this board about the issue.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
JRL
- Year and Model: Several
- Been thanked: 16 times
1st reason, bad propshaft u-joint(s)
2nd reason, bad bevel gear'
3rd reason, bad VC coupler
There are three different propshafts.
They fit:
1:Early 98
2:Late 98 and 99
3:2000
Cannot be interchanged
They fit:
1:Early 98
2:Late 98 and 99
3:2000
sawtooth4x4
- Year and Model: 2000 V70 AWD T5
mine was missing as well. i got a really good one out of the junkyard.
i was going to install it, but the bolts hold that little cross-member in have stripped out. I'm pretty sure the center-bearing on the original one went bad. there were dents all over the metal under the cross member.
I'm going to have to do some cutting and welding to that cross-member someday.
- 15 Replies
- 3656 Views
Last post by shiloh51933
- 737 Views
Last post by JsV70
- 1139 Views
Last post by V50M66
- 774 Views
- 1479 Views
