1997 850 GLT Low Boost Issues
97_boostedgLt
Year and Model: 850 Glt 1997
Post by 97_boostedgLt »
Hello there, i had just bought a 97 850 GLt, I had it for about 3 days now, great running car love this thing but just yesteday it just stopped producing the correct amount of boost! Still runs drives idles and handles like it has 5000 miles on it! So im guessing/hoping it isnt something major because i dont have deep pockets at the momment! Much/any help wouldbe greatly appreciated!!
Reason: Removed *'s from title.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Welcome to the site. I have a '97 855 GLT and I love it too. It's a great car! I installed a boost gauge a while back to see how much pressure the turbo builds up under various operating conditions. It seldom goes above 3-5 psi above atmospheric pressure, often when accelerating up a hill -- at least that's been my experience in general... How much boost are you getting with yours?
97_boostedgLt
Thanks, heard this is the place to go if u have a volvo related question, and as of now i have no boost guage so i dont know exactly how much im making but i can just feel that the car isnt taking off like it use to! I need my GLT to come back to life! lol
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
97_boostedgLt wrote:Hello there, i had just bought a 97 850 GLt, I had it for about 3 days now, great running car love this thing but just yesteday it just stopped producing the correct amount of boost!
Were you cleaning the engine bay, or changing plugs, or poking around? If so, you probably knocked a vacuum line off. Look around for vacuum lines with no mate. Or deteriorated/leaky vacuum line elbows.
Also -> Amazon link
97_boostedgLt
Only thing i did was replace the yellow and blue vacuum lines from the turbo control valve, cleaned the maf sensor and replaced the air filter. Ill check to see if there are any detached lines and corroded elbows and check back with more! Thanks for your input!
wjhandy850
Year and Model: 854 GLT 1997
Post by wjhandy850 »
If the vacuum hoses are up to snuff, and the TCV is good. I wonder if your bypass valve is bad?
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
If it was boosting fine before you replace the vac lines then its something you probably did. I would go back and make sure everything is hooked up correctly.
1996 Platinum Edition
