DIY: Serpentine Belt EZ-Tool (<$2) & Routing Topic is solved
This topic is in the MVS Volvo Repair Database » How to Replace the Serpentine Belt on Your Volvo 850 (and S70, V70, C70)
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Or use a tool we all already have: a 1/2 inch extension on a socket wrench, push it in all the way until it lines up with the 4 splines.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I tried a few times to get a 1/2" extension in there to turn it and could not.
The tool I had made I've been selling for $8 shipped.
osman
Post by osman »
rspi wrote:I tried a few times to get a 1/2" extension in there to turn it and could not.
The hole is bigger than 1/2" its the 4 splines all the way in that make a perfect 1/2" square, You just have to make sure that the 1/2" extension drive is all the way in AND oriented right (the square of the socket drive and the square formed by the splines) otherwise the splines prevent the extension from seating properly in the 1/2" square and when you turn the socket wrench the drive just turns inside the tensioner because it is not far enough in and not fitted into the splines.
Brick Life
99 XC70 AWD LPT 115
osman
Post by osman »
heres a pic of the two different sized squares
This is a picture of both
heres a pic of a 1/2 extension all the way flush inserted into the tensioner. Hint: The wobble extensions will actually "snap" in so that you know you are in right.
here is another from the side
1/2&quot; extension inserted from the side
1/2" extension inserted from the side
Brick Life
99 XC70 AWD LPT 115
eld4au6
Year and Model: 96 855R, 96 855R
Post by eld4au6 »
You all do know you can use a open end wrench on the tensioner. No need for a tool.
its on the pulley below the shown wrench and tool.
osman
Post by osman »
eld4au6 wrote:You all do know you can use a open end wrench on the tensioner. No need for a tool.
So what exactly is that block thing that the crescent wrench is attached to, because it sure isnt part of the tensioner.
Brick Life
99 XC70 AWD LPT 115
osman
Post by osman »
this should be self-explanatory
Brick Life
99 XC70 AWD LPT 115
eld4au6
Post by eld4au6 »
Im talking about the square-ish end of the tensioner that the idler pulley is attached to, can remember what size it was but I used a open end wrench from the bottom of the car.
osman
Post by osman »
I think you have a tensioner that someone has jammed one of these home made inserts into, because that is not a part on any of our cars.
Brick Life
99 XC70 AWD LPT 115
Been thanked: 504 times
Post by cn90 »
osman,
I think I know what "eld4au6" is talking about.
If RED is the usual way of doing this, then BLUE is what "eld4au6" refers to.
Basically:
- Adjustable wrench from below the car.
Here is my sketch, correct me if I am wrong...
