2001 S80 Crankshaft question
I recently replaced the crankshaft position sensor and cam sensor. However, I'm still having issues in starting. It keeps giving the crankshaft position sensor code. Am I looking at needing a new crankshaft all together?
- Year and Model: Lots
- Been thanked: 128 times
The crankshaft sensor operates from reading holes on the torque plate just behind the torque converter. There may be some dirt on the plate or it could be bent.
Another possibility is the wiring leading to the sensor may be faulty. Check the plug for corrosion and even if it looks fine spray it with some contact cleaner. The loom leading to it may have chafing or a short.
- 1109 Views
Last post by ducttapeandzipties
- 243 Views
Last post by jimmy57
