So I've been spending a lot of time experimenting with my s40's base sound system and an FM modulator. I've seen all the posts on various forums about finding the "9v" tab connector at the rear windshield, or finding the connector in the driver's footwell, etc, etc.
So, here's the question - Why two cables? Why not one? In every other car I've ever seen, the antenna cable is a single co-ax with just an inner wire and an outer wire. This Volvo has TWO co-ax cables with an inner wire and an outer sheathing wire. Why? What's the advantage/difference?
The reason why I am asking is because I want to cut into the antenna cable and introduce my FM modulator signal as close to the stereo as possible, for better quality sound. As I was testing the "9v" setup, I found out that even though my FM modulator is supposed to cut out the regular antenna signal when it's turned on, I was still able to get some radio signals because of the fact that the antenna wires that run through the car were still picking up the radio signals.
Based upon what I know about the "9v" setup, I think - tentatively- that I should solder the center wire of the new antenna cable to the center of one wire, and the outer sheathing wire to the sheathing of the other wire. But I'm not sure about that, so I'm looking for a little help...
Thanks, everyone!
Dave
2006 s40 Antenna Cable Spec Question - FM Modulator
DWeisbrod
- Year and Model: 1997 850 NA 5-speed
1997 Volvo 850 5-spd - H&Rs, Bilsteins, Road Rally Equipped
2006 S40i - Manual transmission
1967 MGb - British attitude
1970 Plymouth Cuda - 383, slapstick. Mopar Rocks
______________________________________________
Education • Photography • Design
http://www.weisbrodimaging.com
DWeisbrod
By the way, if you're interested, here is the link to the post I found describing the "9v tab" method...
http://www.volvo-forums.com/t17221-07-s ... ntenna.htm
mf70
- Year and Model: V50 2006
- Been thanked: 2 times
The two cables are there because the output of the antenna amp (16/16 in Volvo docs) is sent to two places (potentially): The AM/FM tuner itself (16/94) and the Traffic Message Channel Module (16/49) if installed.
In addition, I believe that line 2 into the amp carries the 12V supply from the tuner to the amp. Therefore, an FM Modulator inserted between the amp and the receiver would have to pass both the 12V and the signal to avoid blocking all FM from the amp.
- 937 Views
- 4445 Views
Last post by Mikele82
- 9 Replies
- 3062 Views
Last post by mika
- 669 Views
Last post by EdOptician
- 1302 Views
Last post by alschnertz
