98 S70 Missing Cyl Head Bolt Massize Coolant Leak
sven
Year and Model: 03 V70 97 850 R.I.P
Post by sven »
Hi MVS,
Doing a cylinder head on my mom inlaws 98 S70 NA (burnt valve). Im putting in the coolant tonight and I found this big leak on the side of the cylinder head. Looks like a bolt or some sort of sensor is missing...anybody know what is supposed to be there? If its a bolt, anyone know the size?
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
I may be wrong, but isn't that where the upper motor mount arm should be?
5 others that came and went
Been thanked: 504 times
Post by cn90 »
Likely #27 and #28 in the diagram below:
http://volvopartslisle.com/assembly/331 ... inder-Head
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
A plug with seal goes there. They will remove things that are harmed when they vat the head to clean it. The next question is if the machine shop can find the plug.
Post by cn90 »
I thought that hole (directly above the black heater hose) has threads in it.
Has thanked: 311 times
Been thanked: 817 times
Yes the hole has threads, just like the plug that screws in there.
EDIT: #27 and 28 in the diagram you posted are the threaded plug and the seal, you guys are talking about the same thing.
sven
Post by sven »
Thanks for the responses. In case this happens to anyone else....The bolt/plug size is M12 1.5
My local Napa had a BMW drain plug that appears to fit perfectly. Cost was $1.89.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I pulled a head recently and that hole did not have a bolt in it. Was the head new?
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Is that the "bung" that the PCV coolant hose connects to on 99+ models? (Heats the PCV pipe under the intake manifold, coolant flows from it to the thermostat housing)
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
Been thanked: 4071 times
Another MVStery solved!!
