Im not confused about orientation, eld4au6 says that only a crescent is needed, Im saying that the crescent wrench in the picture is clearly attached to a (not stock on the rest of our cars) square that is inserted into the tensioner. We are not discussing what you use to torque the tensioner, but what actually inserts into the tensioner so that leverage can be applied. Quote "all you need is an open end wrench..no need for a tool" Yes need for a tool. The rest of our tensioners dont have a metal block sticking out of them to turn with a crescent. Every one else has manufactured some simple item to fit the tensioner, obviously this guy or his previous owner has built something and after using it probably couldnt get it out, now someone thinks that its part of the tensioner.eld4au6 wrote:You all do know you can use a open end wrench on the tensioner. No need for a tool.
its on the pulley below the shown wrench and tool.
DIY: Serpentine Belt EZ-Tool (<$2) & Routing Topic is solved
How to Replace the Serpentine Belt on Your Volvo 850 (and S70, V70, C70)
- osman
- Year and Model: 2002 c70 hardtop
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- Been thanked: 504 times
osman,eld4au6 wrote:...Im talking about the square-ish end of the tensioner that the idler pulley is attached to, can remember what size it was but I used a open end wrench from the bottom of the car.
You focus in that square hole. "eld4au6" focuses on the square thingy lower down.
The quote above is what I referred to. I think "eld4au6" has his point.
I sketched in BLUE color above.
No need for any tool if you use an adjustable wrench from below!
Basically there is more than one way to skin a cat!
- osman
Now I get it. Your diagram makes it clear. I just wanted an explanation that the wrench in the pic is not the wrench he was writing about. Showing a picture of one method while writing about another was creating too much cognitive dissonance for my tastes. But I love the idea for its simplicity. Sorry for thread clogging.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
QuirkySwede
- Been thanked: 12 times
You're not stealing from them, rather the one who took it. If someone lifts tech from this site via G's cached page for their personal site, would you say G was the victim?eld4au6 wrote:I'm lazy, why take a picture I can steal from google
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Phew, have fun releasing the tension from the bottom and inserting a pin in the top to lock it down.
- osman
Yeah, after hauling out the floor jack and stands just to be able to access the tensioner from the bottom, it doesnt seem like a time saver. I try to avoid doing anything from the bottom that can be done from the topside.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- dosbricks
- Been thanked: 4 times
The pennies work, but I end up mutilating one of them and costing me one cent every time.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
+1 for pennies trick!
Retired:
2015 Volvo S60, T5, 85K
- 425 Views
- 22 Replies
- 35820 Views
Last post by erikv11
- 20 Replies
- 17397 Views
Last post by Hurtfeelings
- 3064 Views
Last post by jreed
- 1436 Views
Last post by skunkd84
