I just got a CEL for multiple cylinder misfire on a 98 S70 T5 with 268k. Cylinder 1,2,and 4 misfire. plugs and wires changed around 250k,pcv system also done 250k, any other suggestions?
Fixed (or i thought i did) problem once, cam sensor plug was interfering with coil, so seperated them and car drove fantastic for 175 miles, after that, boom................ misfire! Car almost cut off but didn't. Any one know a solution to this?
98 s70 t5 Multiple cylinder misfire
volvospeeds70
- Year and Model: 1998 volvo s70 t5
98 Volvo S70 T5 268K miles and counting.....!
2000 Range Rover
2000 Range Rover
when you did the plugs and wires did you also do the distributor cap and rotor? pull the cap off and look for arcing on the contact points.
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Do a quick compression test to see where you are.
Could also be a failing fuel pump or relay. How old is the fuel filter?
volvospeeds70
thanks for the help guys, but she needs a head gasket, oil and water mixed in pretty bad. still runs though. parked in the garage for now.
2000 Range Rover
2000 Range Rover
- rspi
Contact rspi..
Pull the plugs and put some oil in the cylinders and roll it over a few times.
You can also drain the coolant, drain the oil, add some cheap oil, then crank it up for a minute or two. You don't want none of the metal parts to rust and lock up because of the mix.
I purchased a nice S70 GLT once because the car sat for a while with a blown head gasket. The internal parts rusted and locked up the motor. I got some Volans, new tires, Bilsteins, HD brake lines and many other good parts for $250.
- 19 Replies
- 10359 Views
Last post by Barledge
- 9 Replies
- 2983 Views
- 13 Replies
- 6045 Views
- 1299 Views
Last post by movingim77
- 1292 Views
