You are so awesome!!! Xheart for allllll the tips. The lighting was a pain and I had not one, but two head lamps from backpacking in my center console One foot away from my head.. I struggled with two different flashlights. Headlamp is the way to go. My blonde hair full of dirt and antifreeze, now in a hat.
I did use silicone I just need more strength to get it there. Which I dont have so a turnbuckle may the way. I am sooo close to being finished. Thank you again!!!
S80 Heater core replacement
S80 Heater Core DIY
shea44
- Year and Model: S80 1999
Let's see I did finally manage to break the temp control arm that I painfully tried NOT to do. Top pipe seated almost magically after struggle for what seems like hours. Now the bottom one is left to seat which again is impossible or so it seams. Silicone exploded all over me WD 40 company needs to work on their nozzle they all seam to go bad. Silicone does help though, I believe. This by far has been one of the biggest challenges for me. At almost fifty and female, I would liken it to, well I am not sure, but it just a very, very trying project. And misleading, if you are a mechanic of some kind then maybe you would struggle, it's been a two day project!!! and I am still not done! One pipe left to seat, one clip to install then I will need to check for leaks. After all this I hope it works
shea44
The core is in and running.
1. The clips are a MF getting in and out. Can't be said enough. Seating the tubes back in to get the clips took me hours of pushing and finally after only had to get a neighbor to use his muscles to get it.
2. Breaking the temperature control are will probably happen, I even read a tip to turn the car on and turn the heat on all the way to get it out of the way, which I did do and still managed to snap it off and haven't the first clue to get it back in.
3. You do have to remove the brake sensor to get the heater core out, NOT the steering column unless you are a seasoned veteran of auto mechanics which I AM NOT.
I have a new found respect for all mechanics everywhere I am bruised, hands cut and body is very sore. I can't imagine doing it for a living. Thank you all again for your help, tips and suggestions.... Now I have change out the radiator, it's leaking
(((( Did I tell you I am a woman, a girly girl at that. Who has always believed it you're gonna drive it, know how to fix it or be able to afford someone else to. Tata
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Good job!
I am with you, it is among the most complicated removal and install for any first timer. I had difficulty grabbing the brake pedal sensor, it took hours. Turning on/off to move lever away itself was confusing.
I have replaced it on both our cars. Talking about difficulty, I wear tri-focal which doesn't help working in up-side-down situation. Lol!
armandoare
- Year and Model: S80 T6 2000
I know your pain shea44, I just did the same last weekend. The trick to compressing the o-rings was using needle nose pliers to hold them down. My replacement part had a nice little gap that was just the right size to fit the pliers in and squeeze it down. Pushing in the pins was still no piece of cake, and took a lot of force. One went in fine, the other I was happy to have 3/4 in.
Now I am trying to figure out how to reconnect the heater control linkage that I think I may have un seated or disconnected.
Still looking for a diagram.
shea44
I had to get my neighbor who had some muscle to get it the last pipe in. I too broke off the heater control arm thingy at the very end and no clue how to get it in. The radiator being replaced was next. !!! Please post diagram if you find it. Thank yo
shea44
So after all the oring/pipe seating drama. Radiator was also leaking, now changed, hands even more cut up! One of the pipes in the engine area leading to the heater core is leaking. The driver side one. All these repairs seem to lead to another? I love this site and appreciate all of the input, but I may have to through in the towel and trade my girl in. : ( I am not sure men are turned on by a woman with greasy under her finger nails and cut up hands LOL
xHeart
Our Robert's good work...
http://youtu.be/xsDYdsbPfSg
midimykeys
- Year and Model: 1994 Volvo 850
a Volvo shop said today that the evap and a/c would have to be charged after this repair. I have found nothing in this thread about this. Surely this isn't true?
2001 S80 2.9
2001 S60T
3 850s
1985 240 DL
2001 S60T
3 850s
1985 240 DL
- 11 Replies
- 9823 Views
- 5072 Views
- 1374 Views
Last post by ThommyKent
- 638 Views
Last post by Skymongrel
- 32 Replies
- 17691 Views
Last post by sleddriver
