Yes and no,instarx wrote:Actually, turbulent airflow across a heat exchanger is more efficient in removing heat than smooth flow.kcjones wrote:Amen. I don't think the volume of air passing through is increasing, so much as the air doesn't become turbulent when passing by.
This was a studied by a famous rapper named Reynolds...he had a lot of issues and underwent Froudian Analysis eventually.Bloitz wrote:Kind of off-topic but might be interesting nonetheless:Yes and no,instarx wrote:Actually, turbulent airflow across a heat exchanger is more efficient in removing heat than smooth flow.kcjones wrote:Amen. I don't think the volume of air passing through is increasing, so much as the air doesn't become turbulent when passing by.
In very simple terms:
Air has a rather low heat capacity so more volume generally outweighs the benefits of turbulent flow (in the case of air, for water it is very much the other way around).
The radiator has a high fin count and usually the design of the fins will cause the air to go from laminar to turbulent flow.
That being said, the difference relocating the horns will make will be negligible. I think I'll do it though, for the looks![]()
Source: Computer air and water cooling aficionado (If any of you might have computer hardware/cooling related questions, feel free to PM me)
Too bad the photos are Toes Up.tjts1 wrote: 27 Jun 2011, 13:14 Theres room for the horns just above the radiator. You can reuse the existing hardware, just have to drill a couple of holes in the fiberglass radiator support. They should have done this from the factory.
Anybody?????sleddriver wrote: 23 Jul 2017, 17:10Too bad the photos are Toes Up.tjts1 wrote: 27 Jun 2011, 13:14 Theres room for the horns just above the radiator. You can reuse the existing hardware, just have to drill a couple of holes in the fiberglass radiator support. They should have done this from the factory.
I'm curious how the horns are mounted "just above the radiator" on the fiberglass radiator support? Just where is that?
